LinkBack | Thread Tools |
#1 (permalink) |
By the power of Grayskull
Okay so my ECU fried itself (maybe you remember my thread). I got a new one from Gabbergod.
Now its a Fed spec ECU and my car is Cali spec. I was told that it wasnt going to matter by a bunch of people. So I went a head and instaled it, started up kinda slow(starts fine now), it seems like it idles a bit faster than normal. So i decided to take it for a spin. It was driving fine but the it was like sputtering, almost like I'm physically getting on and off the gas but im not. The car ran great before the ecu died so do you think it IS the Cali/Fed problem. If so is there a way to make my car Fed spec? Could it be bad gas still in the system? I put fuel system cleaner and filled w/ new gas the other night. So thanks for reading my short story, any and ALL info /thoughts are appreciated. Thanks guys! ~Mike
![]() ChrisEs1984 : theres alot of pushrod lovers Galganaban : i love to push my rod into your mom shawnisworking : lol shawnisworking : 0wn3d |
#4 (permalink) |
RWARRR!!!
I'm not sure if you situation is the same but there is a buch of us who are having a similar problem and nobody knows whats goin on. Here's the thread on it, Lean Misfires at 2700-2800 rpm
#5 (permalink) | |
Aged Member
Just curious did you put fresh fuel in it after letting it sit for that long?
Our experience of the past and of those dear to us is not lost at all, but remains richly within us.
1991 Stealth RT/TT Garage Ornament..... Quote:
#7 (permalink) |
B FeelGood
Check the capacitors on the actual ECU board. My bet is that they are leaking. I had the exact same problem a while back and I replaced a bunch of un necessary shit only to later find out the problem was the capacitors.
#8 (permalink) | |||
3/S enthusiast
Mods ------------------------- 1991 Mitsubishi 3000gt VR4---------------My website If you live in the Delaware, Maryland, or Virginia area check out our website and 3si chapter forum |
#10 (permalink) |
Go Phillies!
I would try a known good fed spec ecu and see if that solves the problem. Also have you checked your vaccum and intercooler lines?
04 SRT-4 Electric Blue- Sold wtf!
1991 3000GT VR-4 Sold 4 Bolt main conversion, Blitz dual SBC spec r, 3'' Air Filter, Blitz SuperSound BOV, VDO Boost gauge, Polished Y-Pipe, Kormex output shaft and Input spool, Accel spark plug wires with NGK Platinum plugs, 3rd gen lifters, drilled and slotted rotors, blacked-out snakes & turns, Mirage Corp. OBD1 datalogger cable w/Palm m100 Gone: 95 3000GT SL, 94 3000GT, 92 Stealth RT/TT |
