Jason's single turbo build... - Page 11 - 3000GT/Stealth International Message Center
Old 12-02-2011, 07:01 PM   #101 (permalink)
arm0red1's Avatar
Drives: 97 vr4 / 73 mustang
arm0red1 is an unknown quantity at this point
Feedback Score: 2 reviews
Default Re: Jason's single turbo build...
You know, 350z headers mated to our flanges work nicely, they line up pretty much dead on. Kind of a neat trick I'm using in mine, works great plus it let's u free up those ips headers for resale
arm0red1 is offline   Reply With Quote
Old 11-10-2012, 10:52 AM   #102 (permalink)
ajimmyjammin's Avatar
Drives: 91 vr-4
ajimmyjammin is an unknown quantity at this point
Feedback Score: 7 reviews
any updates on this...i just ordered a comp 67 for my 3L car.....wondering if you got yours running.
really big and alllllllll the way out into the flats!!
ajimmyjammin is offline   Reply With Quote
Old 11-10-2012, 01:02 PM   #103 (permalink)
Breaks everything
JasonY's Avatar
Drives: 1999 VR4
JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3JasonY Level 3
Feedback Score: 38 reviews
Nope...went twin gtx turbos instead. Singles just don't work that well comparedd to a good set of twins...
Silverstone Metallic 94 R2 FD.
Sold: Black 99 VR4 and two Pearl White 93 VR4's.
JasonY is offline   Reply With Quote
Old 11-23-2012, 06:49 AM   #104 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
Feedback Score: 0 reviews
I don't think I have a seen the proof of this. There have been what...a handful of people to attempt singles and actually give it a fighting chance and then there are hundreds of cars that have twin setups that Matt or someone else already dialed in. The success is behind the creator, not twins vs singles. I would also note that some of the nastiest twin setups are basically a single setup with 2 turbos (running the turbos over the transmission) so blaming exhaust length is invalid. We do have a lot of people who don't pick the right parts for their setup/goals. Easier when someone else has it figured out for you.
Brent - Great Depression Racing
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765
Now, Stock 10:1 diamante 12 valve shortblock with regapped rings. Stock heads/cams. Waiting.
1994 Spirit - 13.85@108.8 - SOHC - 10psi - Holset He341 & chrome rings.
1981 Starlet KP61
http://www.youtube.com/watch?v=AXF2c...saCIg4HZ3MmpVw
Ondontii is offline   Reply With Quote
Old 11-23-2012, 01:09 PM   #105 (permalink)
vr4tune's Avatar
Drives: 1997 3000gt vr4
vr4tune is an unknown quantity at this point
I agree that a single can perform as well as twins if set up properly. Well the problem is that is so much more work to fab up a single turbo, than to bolt on a set of pre made twin manifolds. The only production single set up (IPS) requires the removal of a/c.
Ported heads, IPS 2mm oversized valves, Delta 264/272 cams, 3SX cam gears,
Merkel 6g72 3.5L BILLET crank stroker (going in this summer),
IPS EvoIII turbo kit, HKS SSQV bov, ETS black anodized FMIC, AEM intake filters, Tanabe Turbo Back Concept G Blue Exhaust,
HKS DLI, Ultra spark plug wires, Denso iridium IK24 spark plugs,
JSPEC trans, Ultimate Performance short throw shifter, Spec carbon twin disk clutch, PST aluminum 2 piece drive shaft,
Denso Supra fuel pump, RC 750cc fuel injectors, AEM wideband & boost gauge, AEM EMS in speed density,
3sx poly motor mounts, DBA 4000 drilled & slotted rotors, Enkei PF01 18x9 +45, BFGoodrich g-froce KDW 245/40/R18.
vr4tune is offline   Reply With Quote
Old 11-27-2012, 03:37 PM   #106 (permalink)
Smooth and Fast
Erron Spalsbury's Avatar
Drives: Race Car
Erron Spalsbury Level 1Erron Spalsbury Level 1
Feedback Score: 22 reviews
My single works exceptionally well.
Erron Spalsbury is offline   Reply With Quote
Old 11-28-2012, 11:39 AM   #107 (permalink)
Ondontii's Avatar
And it is on a road racing car where the supposed "huge" downside of a single turbo would be a problem. Plus your turbo is quite large. Drag racers not able to use a single turbo have a driving problem. Some people do have an obsession with racing in the wrong gear though... "I put 3 car lengths on him from 2000 to 3000 rpms!"
Old 11-28-2012, 04:25 PM   #108 (permalink)
Smooth and Fast
Drives: Race Car
LOL!
Here's some car lengths being putting on some guys...
(sorry to hijack)
Old 11-28-2012, 06:49 PM   #109 (permalink)
Breaks everything
JasonY's Avatar
Drives: 1999 VR4
Road course is actually the single most ideal application for a single turbo imo. What turbo are you running now Erron? 4094R?
Jason
Old 11-28-2012, 06:55 PM   #110 (permalink)
Smooth and Fast
Drives: Race Car
Yes sir, correct. GT4094R
