Old 04-25-2008, 10:17 AM   #1 (permalink)
just some guy.
Racer_X's Avatar
Drives: 94 Stealth Turbo
Trader Rating: (9)
Racer_X Level 1Racer_X Level 1
Default I made my own Aftermarket hood struts....here's how
after measuring, mixing, matching, weighing, etc, I figured out how to make the best aftermarket hood (fiberglass/carbon fiber) hood struts for my 94 Stealth. My hood has provisions for M6x1.0 bolts for the hood strut in the same area as stock. Stock size is larger (8x1.25 I think). Here are the parts I boght to make them (purchased at McMaster-Carr)
9416K342 40 lb gas springs x2
9512K73 ball studs x2
6275K53 6x1.0 right hand thread tie rod ends x2
9416K74 ball stud sockets x2
5/16-18 nuts x2
all of this cost me around 50 bucks.
here is what you have to do:
1. remove stock hood struts
2. using a 5/16 (or slightly larger) drill, drill the strut piston mounting stud out of the stock strut brackets
3. screw the ball stud sockets onto the piston end of the gas springs
4. install the ball studs in the factory bracket with the ball portion facing inwards
5 (requires cutting) trim down the back side of the ball stud/nut assembly to allow for fender clearance. I had to cut my nut in half, but it still holds just fine, plus it is so close to the fender when installed, that it isn't going anywhere
6. cut the base of the 6x1.0 tie rod ends down so that the barrel end of the gas shock bottoms the head of the thread inside of it (the hole in the tire rod end is threaded all the way down and is made of aluminum. Measure the length needed with a sample 6mm bolt)
7. Screw the tie rod end into the hood (I used needle nosed pliers to do this with. don't overtighten it. just get it in so it is threaded as far as it will go)
8. Lift up the hood really high and thread the gas strut assembly into the tie rod end
9. carefully compress the piston just enoguh to pop the piston end on the ball strut
10 DONE.
The stock hood struts are 100 lb gas springs (very heavy). A slightly less strength proportional equivalent for my hood would require 40 lb springs, so that is what I use. they are JUST strong enough to hold the hood upwhen ti is almost fully open, and the closer you get to fully open, the springs will actually provide positive lift. it isn't enough force to damage or warp anything, and everything clears properly (I did have to trim a corner off of an inner fender piece on the driver side with a dremel, but it was VERY minor).
DO ONE AT A TIME!!!!!! You may have to trim the ball stud socket some as well to provide adequate clearance, but I doubt it. Also, if your hood is heavier than my hood, you may need a set of 50 lb springs instead of 40 lbs (also doubt it, but the stuff is cheap anyway). When bolted to my car, the hitch weight on my hood was 12 lbs (measured at the hitch with the hood bolted to the hinges. The weight of my stock hood measured the same way was 28 lbs. You may want to take this into consideration.
enjoy
Pretty good for 2 shot turbos and a boost leak
Racer_X is offline   Reply With Quote
Old 04-25-2008, 11:09 AM   #2 (permalink)
Drives: 94 VR4
Trader Rating: (6)
ilmuto is an unknown quantity at this point
Default Re: I made my own Aftermarket hood struts....here's how
very nice write up! lets get some pictures posted up
ilmuto is online now   Reply With Quote
Old 04-25-2008, 11:22 AM   #3 (permalink)
oohnoo's Avatar
Trader Rating: (130)
oohnoo level 6oohnoo level 6oohnoo level 6oohnoo level 6oohnoo level 6oohnoo level 6
TITS!
What hood do you have for comparison? And by hitch weight you mean the weight of the hood when measured at the hood catch when lifting up?
----------------[2007 Ride of the Year
"Stroke" her I did. And I got the dual balls to prove it
Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP
Making & Selling - Converted DSM IC's........Dual Core FMIC........EGR Blockoff Plates
oohnoo is offline   Reply With Quote
Old 04-25-2008, 12:01 PM   #4 (permalink)
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (37)
Boostaddict is an unknown quantity at this point
Armond has the deft top secret hood. I don't think my "regular" 2g deft hood has provisions for hood shocks (don't remember)??? Strange as I'd assume they'd use the same under-hood skeleton
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
Old 05-07-2008, 08:48 AM   #5 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (61)
Black_Sunshine Level 1Black_Sunshine Level 1
i second this. pix would help us better understand what you did.
Black_Sunshine is offline   Reply With Quote
Old 05-07-2008, 08:50 AM   #6 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 1mywetdream Level 1
i have been using my stock oem struts...but my hood was open for 5 months ...so mg guess it weaken them enough to work with my c/f hood...but they are strong enough to hold my stock hood up as well
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 05-07-2008, 11:44 AM   #7 (permalink)
Dutch by nature!
Drives: 3000GT VR4
Climber is an unknown quantity at this point
I'm sorry to hear that
Seems like a lot of work to save $50 compared to the 3sx struts.
Life's too short to go slow.
Climber is offline   Reply With Quote
Old 05-08-2008, 05:27 AM   #8 (permalink)
just some guy.
Racer_X's Avatar
Trader Rating: (9)
not really. if I had to do it all over again, I could have the whole thing assembled in about 15 min. My time is valuable, but not THAT valuable (plus 50 bucks can be best used on other ways.......like gas ).
Old 05-08-2008, 05:38 AM   #9 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (53)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Nice. Any chance we can get pics of the hood open and closed?
Old 05-08-2008, 06:31 AM   #10 (permalink)
Dutch by nature!
Drives: 3000GT VR4
Would any of these work?
eBay Store - The Parts Store: SUSPA Gas Springs Shocks Strut:
