Old 09-17-2006, 10:58 PM   #21 (permalink)
This SUCKS!
StealthRTSC's Avatar
Drives: 93 Dodge Moneypit RT
Trader Rating: (51)
StealthRTSC is an unknown quantity at this point
Default Re: I have to rebuild....
the russian on crack down, Hope you get a block and get that car on the roll again!!
StealthRTSC is offline   Reply With Quote
Old 09-18-2006, 12:24 AM   #22 (permalink)
lover of everything Greek
Linebckr49's Avatar
Drives: 93 3000GT base
Linebckr49 is an unknown quantity at this point
Originally Posted by J-Groove
Wait, wait, I see a light at the end of the tunnel.
http://www.3si.org/forum/showthread.php?t=343051
My only hope is that it is still available. Would be a nice to pick up a long block for that price.
i can tell you that engine in the link is sold. its now in Vagrant's car, and running like a beauty!
Originally Posted by rush6432
Wrong the 10:1 will be just as reliable and more off boost power. its all in the tuning. if your too scared to deal with the 10:1 and affraid of blowing somthing then i dont know if you should be even doing a tt conv/swap at all. not trying to be a dick but if you can tune 10:1, then tuning on 8:1 is a joke, you have way more room for error than you do on a 10:1. i ran the single t67 for a while and beat on it quite a bit and it was reliable. prior to that i had 13ts that i DAILY DROVE in houston in stop and go traffic with a 6 puck clutch and it was still reliable as the car was when it was n/a. Keep in mind this was all 10:1 compression. also before 13ts i was daily driving with the 9bs, ALL of my turbo setups were on the stock n/a radiator too. the car will be reliable if you DONT cut corners. 10:1 can be just as reliable as the 8:1 motor. im not trying to push 10:1 here but take a step back and look at the pros and cons of each. 10:1 cant run TONS of boost on pump gas, but will spool quicker and can make slightly more power at low boost levels than a tt at ALMOST double the boost with same turbos. if you want to run tons of boost and throw big turbos on and make tons of power id say go 8:1. If you just want more passing power or 40-50 more hp go 10:1 and save yourself some $$$. If you really want to be nuts take 10;1 and throw big turbos on and see what you can do. i can attest to the stock internals being stout, the single turbo setup i ran was pushing 12 psi on pump gas and took it like a champ. take advice from the few that have gone every route, we know what we're talking about and its gonna save you money in the long run. if you want im willing to probably just give you a non turbo short block. its bare, no pistons,crank or rods. i have the gurdle at my house and the block at adams (15-20 min drive from my house) if your willing to drive down here to austin, id give you the block.
take Jeff's advice. he knows what he's talking about, been there, done that. go pick up his short block. and don't fret about getting something for free. you can inspect the block as much as your heart desires. heck, i'm sure Jeff and/or Adam will help you inspect every inch of it. good guys to get parts from.
John, good luck on getting your ride back up and running!
Linebckr49 is offline   Reply With Quote
Old 09-18-2006, 09:39 AM   #23 (permalink)
Tad Costin
Lets_rock's Avatar
Lets_rock is an unknown quantity at this point
Got a stripped down 99vr4 block, less than 8000 miles on it. I think I still got the internals too. Make an offer I cant refuse and I may let it go. Dont have time to swap mine yet. So I do not know if I will ever use it. Had it for couple years in my garage already.. Im in Houston...
94 3k base. ALIVE !
92 integra. almost fixed
94 prelude si H22. Running on pace maker.
Mods:
1. Peanut butter on breakpads(anti squealant)
2. Duct taped air intake (cant fix it Duck it)
3. Rubber cement on tires (traction)
4. Sewage hose air ram.
5. yellow spray paint on calipers (if it looks fast, it must be)
Lets_rock is offline   Reply With Quote
Old 09-18-2006, 09:47 AM   #24 (permalink)
I’m going to try and respond to everything in one quick post.
Good news is, I got some sleep last night, got up this morning for my 2 mile jog and currently on a short break b/w some classes. So I have a clear head and no longer worried about this situation.
Linebckr49: I should have known a deal like that wouldn’t have lasted this long. I’m definitely going to be taking in Jeff’s advise, heck the amount of his threads I have read during my research of this project. Almost all of my decisions are based on Rush and Mike95’s contributions on the subject.
Rush6432: Thank you for chiming in and for the offer on the block. I want to take you up on your offer for the short block, mainly because I know you won’t sell me something you know to be bad. My question is, what do you think about me reusing my stock internals in the new block? The car has 110K+ on her, and the plugs were on their way out when I pulled them the other night, but she was running like a champ and recently did a cross country trip from Texas to South Florida and back with no problems.
I do want to try and keep this under $1,000 (if at all possible) without cutting corners, I do want to try and be as affordable as possible without going cheap.
Presto97sl: I’ll be graduating in May, but I will be up in Waco from time to time. You will have to join the Baylor Driving Club, a big group of us will be graduating, but we are bringing up a good guy to take over as president. He has a Dodge Diesel flat bed that runs a 14.01. It is crazy to watch that 6K pound beast go down the track.
I’ve never rebuilt an engine before, no better time to learn than now.
Old 09-18-2006, 10:16 AM   #25 (permalink)
Puts Out On 1st Date !
Show Killer's Avatar
Drives: 9 HootersGirls A Day
Trader Rating: (31)
Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7Show Killer Level 7
You'll need an engine stand. I'll sell you mine for a decent price since i won't be needing it anymore.
Driver of Turbo Dodges. A '92 Stealth RT/TT and an '03 Ram 2500.
Stealth - 15G's,FMIC,E-Manage Ultimate and other supporting goodies
Ram 2500 - Single turbo, FMIC and 4" exhaust (aka-stock)
Show Killer is offline   Reply With Quote
Old 09-18-2006, 10:30 AM   #26 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Fuck.
I hate to be the barer of bad news, but Jeff, all those blocks got junked because, well, they were 2-bolts or non-turbo 2-bolts (even worse).
With that said, finding a block shouldn't be hard. Just keep your eyes open in the parts-for-sale section, you'd be surprised just how many people have blocks laying around. Look for blocks with a spun bearing (rod), but when you tear it down, pay attention to the condition of the main/thrust bearings. If they look bad, you might want to keep searching.
Ugh... I still have that oil cooler if that helps... lol
*edit* What a freakin' AWFUL way to end up with a bad block. Is there anyway the whole area can be welded? Perhaps you can try welding it, grinding it flat, and NOT using that bolt hole. As sketchy as that sounds, it sure beats a rebuild.
*edit#2* OMG I didn't see how far that crack extended.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 09-18-2006, 10:54 AM   #27 (permalink)
n' the dragon comes@niiii
morfinx's Avatar
morfinx is an unknown quantity at this point
John, dude I just stumbled upon this thread during lunch break. I'm sorry to hear that, that really sucks! I hope you get it put together soon, you know I'd definitely help you with that if I was still in Waco.
I think you should take the most economical route (without cutting too much corners). Being that you are still in school, large debts should to be avoided if at all possible. Give me a call if you need emotional support lol.
BAWC FTW
92 3000GT SL 5-Spd "Calixta" [SOLD!!]
- The Trent
morfinx is offline   Reply With Quote
Old 09-18-2006, 11:46 AM   #28 (permalink)
Between Shadow and Light
iceman_ii's Avatar
Drives: Abbie & the N/A
iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7iceman_ii Level 7
Funny you should ask that, Before lunch, I shot xwire an email asking him to take a look at the pictures to get his opinion about just that!
Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end...
Author unknown
485 awhp (mustang dyno) on 93 pump gas (~524 dynojet equivalent)
Only 20.5 psi on my lil' ol' GT368s with no water or alky injection
With a wee bit more tuning, I should get it to about 22psi
iceman_ii is online now   Reply With Quote
Old 09-18-2006, 11:54 AM   #29 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7Barefoot Level 7
I don't know if you know what you want to do. But if you wanted to rebuild a 10:1 engine.. or rather a 2bolt with no oil squirters, I have a spare striped (Should I use the work empty instead?) NA block lying around.
*EDIT* It spun a bearing, so the cylinder wall are in good shape
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Barefoot is offline   Reply With Quote
Old 09-18-2006, 12:14 PM   #30 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: with EDFC at 0/0
LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7LVA3KGT Level 7
Hey John,
It's been a while! Sorry to hear about your engine. I'm not sure what kind of advice to give you, seems you have plenty here already. Good luck man!
97 SLtt
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
(Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.8MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
