LinkBack (5) Thread Tools
Old 04-16-2008, 05:03 PM   #71 (permalink)
Ex-VPC Headbanger
David_J's Avatar
David_J is an unknown quantity at this point
Default Re: Hydrogen Generator/Hydrogen Injection Systems
Depends on the potential energy needed to disassoicate NH3 in comparison to H2O. My recollection is it is lower
Post your before and after test data and let's see what's cooking...hopefully, not your engine.
David_J is offline   Reply With Quote
Old 04-16-2008, 05:45 PM   #72 (permalink)
Average poster
DBLerman's Avatar
Drives: '94 3000GT
DBLerman is an unknown quantity at this point
Originally Posted by DANTHEVR4MAN View Post
Yeah I am seriously doubting the major claims such as that but even if its possible to get 10% increase lol im going to be paying like 80-90$ a fill up
Judging by my calculations using the energy density of gaseous hydrogen (.0108MJ/L) at the rate you have given, and the energy density of gasoline (34.6MJ/L) at the rate it is used, you're looking at an increase of .2%(rounding up) energy over just using gasoline alone. I'd say that's about 250ft/gal more you will get. Less than a football field.
Note: All of my calculations assume ideal standard temperature/pressure conditions.
DBLerman is offline   Reply With Quote
Old 04-16-2008, 06:09 PM   #73 (permalink)
DANTHEVR4MAN's Avatar
Drives: 1991 VR4
Trader Rating: (10)
DANTHEVR4MAN is an unknown quantity at this point
Haha yeah me too I wont be installing anything until I have the emanage ultimate/speed density, and all the gauges/monitoring
will have scanmaster 3 for wbo2/knock with my lc1
egt, volt,
already have boost, oil temp, oil pressure, water temp, fuel pressure. once all that is setup and running smooth then I will worry about this
1991 3000gt VR4
- 19T HL - AEM AFR, & Fuel rail loop - Wallbro 255lph with hotwire - EVO 560cc injectors - Maft gen2 with LC-1 - Apexi AVC-R - Stainless headers, and downpipe no cats - ARP Headstuds - 3rd gen lifters - Kevlar timing belt - HKS SSQV - Vac reduction - 85mm Maf with dejon bow-thru - FF Dynamics Aluminum radiator, & Fans - Prosport Gauges - Robomod Headlights with Custom BMW style halo rings - Racing Hart J8 Gold rims
DANTHEVR4MAN is offline   Reply With Quote
Old 04-16-2008, 06:11 PM   #74 (permalink)
Drives: 1991 VR4
Trader Rating: (10)
I think I will most likely do 6-8 cells as I don't think the 1-2 liters per minute is enough either. But 16 liters per minute would be much more substantial.
but the fact that the fuel is more fully burning is "supposed" to make the big difference in theory not the amount. I see what you are saying though it may do nothing
Old 04-16-2008, 06:24 PM   #75 (permalink)
3000GT_Rider is an unknown quantity at this point
I thought it took more energy to electrolisize water into H2 and 02 than would be gained? How can more economy be gained from an energy negative process?
First law of thermodynamics:
"Energy can not be created or destroyed...."
It is taking X amount of energy to break the bond of h20. Where does that X come from? Driving the alternator. Since machines are not 100% efficent, and there are frictional and electrical losses it seems more energy is put into the system than can be netted out of the system. Anyone care to elaborate on this?
3000GT_Rider is offline   Reply With Quote
Old 04-16-2008, 06:29 PM   #76 (permalink)
Proud 3000GT Driver
drone007's Avatar
Drives: 1994 3000GT Base-TT
drone007 is an unknown quantity at this point
not to mention his sig video is racist as hell
drone007 is offline   Reply With Quote
Old 04-16-2008, 06:33 PM   #77 (permalink)
Average poster
DBLerman's Avatar
Drives: '94 3000GT
Keep in mind that even 16L/min is still EXTREMELY minuscule in comparison to the volume of air already entering your engine.
Just wondering where you are going to get 6-8 times the energy? Do you plan on storing 6-8 extra batteries in your trunk?
As far as the ammonia question. I'm pretty sure the H2 output would be similar to the NaOH and KOH, since NH3 dissociates to NH4+OH when mixed with water. Plus commercially available ammonia is already very dilute. I would also suggest against it because ammonium hydroxide is a volatile compound and will release corrosive ammonia into your engine.
Old 04-16-2008, 06:34 PM   #78 (permalink)
broke joke
zba857's Avatar
Drives: 6spd 92'
zba857 is an unknown quantity at this point
subscribed
edit:
(my avatar isn't racist... its nazi-schumacherist )
92' firestorm VR-4 - complete 96' JDM drivetrain - 92' electronics/sensors - UR cam gears, flywheel - DNP pipes - Stillen intake, rotors - 3sx downpipe, steel braided lines, subframe/diff bushings, control arms, plennum spacer - Tein s - denso IK24 - Apex'i AVC-r - MP solid mounts - Spec 3 - Vacc reduction
Deleted - ALL emissions, AA, antenna, rear wiper, front washer bottle, batt relocate, 4WS
zba857 is offline   Reply With Quote
Old 04-16-2008, 10:29 PM   #79 (permalink)
Ex-VPC Headbanger
David_J's Avatar
They aren't claiming that the extra power is coming from burning the H2 directly. They say that it increases the efficiency of burning the gasoline.
Old 04-17-2008, 03:40 AM   #80 (permalink)
Drives: 1991 VR4
Trader Rating: (10)
I didn't really think it was racist its just silly/funny do you have an issue with it?
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/hydrogen-generator-hydrogen-injection-systems-414833/
Posted By For Type Date
rust electrolysis | Topic profile | BoardReader This thread Refback 04-19-2008 09:49 PM
Untitled document This thread Refback 04-17-2008 04:40 PM
hydrogen injection :: BoardReader This thread Refback 04-15-2008 02:09 PM
Untitled document This thread Refback 04-13-2008 02:41 PM
Vegas3S Forum • View topic - Nate, we need to play with this concept! This thread Refback 04-11-2008 05:39 PM
