How to: Rewire active aero wing for manual operation. Stock switch. - 3000GT/Stealth International Message Center
Old 04-10-2010, 10:57 PM   #1 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
stupidvr4 is an unknown quantity at this point
Feedback Score: 9 reviews
Default How to: Rewire active aero wing for manual operation. Stock switch.
I dont know if anyone has done this yet. But if nobody has, here it is. Ever since I installed my front mount and had to remove the front motor, my wing never worked properly. So i either had to live with it, or find a way to bypass the front motor. I managed to rewire the wing off the stock switch to work manually. I can raise it up, down, halfway, a quarter way, where ever I want it. Unfortunately I didnt take any pictures, but its not that hard.
You will need:
2 - 5 pin 12v relays
Some male + female wire connectors
some wires of course
and basic electrical tools (wire strippers, snips)
First disconnect the battery.
Next remove the trunk plastics to get to the Active aero control unit. Its the bigger metal box to the left of the active exhaust motor.
You will see 2 connectors plugged in. The white one controls the front and rear motors. The other one sends the speed snsor signal and instrument cluster signal etc.
On the white plug cut the Red-Black wire, and on the black connector cut the Blue-White wire and splice them together. Now on plug that goes into the switch up front, theres a black ground wire. Cut that and tape it up. Now the switch has a constant power. Make sure your bulbs in the switch work because current has to go through one them in order to get power to come out of the switch.
Next go back to the trunk and bring out the relays. The ones I used have the usual 85, 86, 30, 87 and 87a. With 87a being normally closed. Now heres where it might get a little messy. Put the relays side by side and do this.
-On both relays ground pin 86 and 87a.
-On one relay cut and splice the Red-Blue wire from the black connector to pin 85. Then cut and splice the Red-Blue wire from the white connector to pin 30
-On the other relay cut and splice the Yellow-Black wire from the white connector to pin 85. Then cut and splice the Red-White wire from the white connector to pin 30.
Now cut and splice the Black-white wire off the black connector, and split it to pin 87 on each relay.
PICS OF THE RELAYS IN POST #12.
Plug the connectors back into the control unit, so its still keeps the motor cut off switch (so it doesnt burn out if you accidentally leave the switch down for too long). Test it, then have fun waving at people.
This worked perfectly on my car, and costed about $20. The switch gets power straight from the fuse box, but the wing only gets power when the key is on, and one of the switches is closed. If you have any problems with it, I'll double check my wiring and get back to you.
At the switch, on the switch itself, cut the red wire and cut the black wire that's next to the green one. Connect the black one from the switch to the red one from the connector. The black ground you cut is the only solid black wire(might have silver dots on it) on the car harness side of the connector. See pics:
stupidvr4 is online now   Reply With Quote
Old 04-16-2010, 08:30 PM   #2 (permalink)
3SNY FTMFW
mikemet28's Avatar
Drives: A Quarter Horse
mikemet28 is an unknown quantity at this point
Feedback Score: 8 reviews
Default Re: How to: Rewire active aero wing for manual operation. Stock switch.
wow awesome write up going to try this this weekend.
Photobucket
Photobucket
mikemet28 is offline   Reply With Quote
Old 04-16-2010, 09:45 PM   #3 (permalink)
Goallie11's Avatar
Drives: 92 3000GT VR-4
Goallie11 is an unknown quantity at this point
Feedback Score: 7 reviews
Wow finally someone does this!
Do you think theres anyway to streamline it?
1992 3000GT VR-4
DR650s,Denso 550 injectors, Walbro 255, Emanage Blue,3SX Cat Eliminator Downpipe,Short Shifter,DNP Hardpipe Kit,HKS SSQV,Underdrive pulley,Carbotech slotted rotors,RPS Lightweight Flywheel, Maximal Solid Mounts
2003 ZZR 600 (Sold)
Goallie11 is offline   Reply With Quote
Old 04-16-2010, 10:47 PM   #4 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
Sorry brain fart. Streamline?
Old 04-17-2010, 01:05 AM   #5 (permalink)
Goallie11's Avatar
Made simpler.
I don't know much about wiring, so I don't know if that's already pretty simple, but I'm definitely glad you've figured it out for all the people that don't have their AA working.
Old 04-17-2010, 10:44 AM   #6 (permalink)
soon to be 16G
THOR'SVR4's Avatar
Drives: RT & VR4
THOR'SVR4 is an unknown quantity at this point
guess what im doing today
thanks for the write up
go fast bits...
hot wired 255lph fuel pump, 550cc injectors, 3sx fuel rail loop, bigger fuel lines, K&N cone filters, Dejon 'blow through' intake pipes, GM LS6 MAF, MAFT, Robbeck 13T turbos, FMIC with full alu piping, MSD wires, 3sx radiator,HKS EVC electronic boost controller, turboxs R.F.L. BOV, maximal performance T case brace, Clutch, new output shaft / rebuilt T case, A/C delete, vacuum delete, AEM wideband O2, solid motor mounts, short throw shifter, 3sx ross pistons, 3sx rods w/ ARP bolts, new oem forged crank, clevite bearings, B&M oil cooler.
Tuned by Ray Pampena at 3S Motorsports, 418 AWHP / 408 AWTQ @ 18psi.
THOR'SVR4 is offline   Reply With Quote
Old 04-17-2010, 02:47 PM   #7 (permalink)
machzrcr's Avatar
Drives: 1995 VR-4 , 1994 SL
machzrcr is an unknown quantity at this point
Feedback Score: 17 reviews
thats awesome! gunna have to do this! any pictures to help with the wording?
1995 VR-4 being rebuilt with lots of extra goodies!
machzrcr is offline   Reply With Quote
Old 04-17-2010, 09:21 PM   #8 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
Paintbrush lol. This pic seems small from the preview but it shows the color wires you cut and splice. The left side is from the black connector harness and the right side is from the white connnector harness.
And you can see which wires to cut on each connector, and the ground wire to cut on the switch up front (top picture)
relays are set up like:
86....30
85.87.87a
This is all you have until tomorrow
Old 04-17-2010, 09:24 PM   #9 (permalink)
Hemi417's Avatar
Drives: 93 vr4
Hemi417 is an unknown quantity at this point
Feedback Score: 6 reviews
hey thanks subscribing thanks goallie
Hemi417 is offline   Reply With Quote
Old 04-18-2010, 11:50 AM   #10 (permalink)
machzrcr's Avatar
ok i tryed this got it all wired up! do i have to have the car running in order for it to work? or just the key in the accessory position
