#11 (permalink) | |
never a dull moment
Name one corner I cut on it? I am not the corner cutting type, I just want to check other things before I go dumping more money into the car. Coop
![]() To many mods to list. |
#15 (permalink) |
Mr. Chocolate...
Oh Snap.
Personally..I'd have waited on building up the engine and spent that same $ on proper manifolds....but that is ME not you Cooper. Your setup is your setup. Like Jeremy says, you are building it for YOU not for us. But at least rebuild the turbos on the Sandstone before you run it..if you do nothing else.
![]() Current Car: 1997 Black Top Red Mitsubishi 3000GT VR4 - 93k miles and stock ~ For Sale <~click me! Cars Owned: 1992 Dodge Stealth RT (sold) 1992 Mitsubishi 3000GT VR4 #1 (parted) 1992 Mitsubishi 3000GT VR4 #2 (sold) 1993 Mitsubishi 3000GT VR4 (KIA) 1994 Mitsubishi 3000GT VR4 (sold) 1994 Mitsubishi 3000GT Base - awd/atx (sold) |
#16 (permalink) |
TEXAS!! FIGHT!!
I made 488 AWHP @ ~20 psi on 14B's with plates. Others, like pacman, 2mitsus, and others have dyno'ed in the 500+ AWHP range on adapter plates. Don't think for a second that you're "the first"
LOLAnyway, the big advantage to tubular headers is pump gas power, IMO. Buy a used 9B for like $200 and put it on. It sounds like putting that turbo on ANY running engine would be a bad idea. Turbos DO have the ability to dump your engine oil at a very high rate. Do you want oil pooling in your intake or exhaust?
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01 (Trevor owns me )E16G's: 11.28 @ 124.7 (Pure pump gas ET record )14B's: 11.10 @ 127.3 (AWD 14B ET record. Take THAT, Trev! 9B's: 12.78 @ 107.1 Congrats to the current top 10 members!! DynamicRacing: US 3S Top 10 Fastest List |
#17 (permalink) | |
never a dull moment
Coop |
#18 (permalink) | |
never a dull moment
Coop |
#19 (permalink) | |
Mr. Chocolate...
Keep in mind, that just because you aren't spinning up the turbos to full boost doesn't mean that they won't dance around and scrape the shit out of the housings further exacerbating the problem ![]() |
#20 (permalink) | |
never a dull moment
Yep I could cause problems to the turbos but really how much could it cause to put it together and start it? Why would I rebuild the turbos when I dont know the condition of the engine? Hey lets throw so much money at it that we fix everything first before we know the condition of anything? Coop |
