Old 11-20-2009, 11:39 AM   #1 (permalink)
dissturbbed is an unknown quantity at this point
Default how do i torque the cam pulleys
i just put on new cam seals and etc. now its time to torque the pulleys or sprockets back onto the cams. I dont have a special tool to hold the cam steady while i torque the pulleys onto the cam, i was wondering if anybody has a technique or improvised way to do this..
dissturbbed is offline   Reply With Quote
Old 11-20-2009, 12:13 PM   #2 (permalink)
Minnesota 3/S
chevelle5434's Avatar
Drives: 1995 3000gt SL
Trader Rating: (7)
chevelle5434 is an unknown quantity at this point
Default Re: how do i torque the cam pulleys
You will need to take the valve covers back off, there is a spot on the cam to put a wrench. I think its like a 22 mm wrench you will need. Hold the wrench in place while torquing the bolt for the cam pulleys.
chevelle5434 is offline   Reply With Quote
Old 11-20-2009, 12:14 PM   #3 (permalink)
oohnoo's Avatar
Trader Rating: (214)
oohnoo Level 1oohnoo Level 1oohnoo Level 1
Big ass adjustable wrench on the hex portion of the cam. Just be carefull not to touch the cam lobe. I also lean the wrench against the head as a brace only on the far side (Front intake, rear exhaust) standing at the engine front. For the other near side (front exhaust, rear intake) I place a block of wood as I was always afraid it could crack the head wall.
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
oohnoo is offline   Reply With Quote
Old 11-20-2009, 01:49 PM   #4 (permalink)
thanks a million..you saved me..big time!!!!!!
Old 11-20-2009, 01:52 PM   #5 (permalink)
thanks for the replies fellas
