Old 06-28-2008, 04:46 PM   #1 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5
Default hood props for aftermarket hoods.
What interest would there be for a hood prop to hold your fiberglass/carbon fiber hood open?
I have a prototype that...
stows under the hood,
pivots
snaps down (to prevent noise)
is light weight
cut to fit different hoods
no drilling/cutting on the car
installs in seconds
and is currently holding up my stock hood (w/o struts).
Pricing would depend on shipping, but im thinking $20-$30 shipped.
sorry, I cant show better pics.
if I can get 10 that I know will pay then its a go.
if your interested, sign up here
badass3000 is offline   Reply With Quote
Old 07-23-2008, 09:11 PM   #2 (permalink)
badass3000's Avatar
Trader Rating: (20)
Default Re: hood props for aftermarket hoods.
around $8 in parts. (from left to right)
rubber insulated electrical tie down = hinge
rubber tube to keep rod silent under vibration
1/4 steal rod bent in vise
rubber 'cork' to keep the tip from putting a hole in your hood
rubber adhesive white receiver/cup to stick on hood (optional)= doorstop
Parts all from HomeDepot or Ace True Value.
Old 07-23-2008, 09:17 PM   #3 (permalink)
oohnoo's Avatar
Trader Rating: (156)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Excellent!
Major thumbs up for sharing.
oohnoo is online now   Reply With Quote
Old 07-23-2008, 09:51 PM   #4 (permalink)
Certified *** BADASS
superinflamo's Avatar
Drives: 1995 3000GT VR4
Trader Rating: (11)
superinflamo Level 7superinflamo Level 7superinflamo Level 7superinflamo Level 7superinflamo Level 7superinflamo Level 7superinflamo Level 7superinflamo Level 7
does it hook up to the center latch? or just has the hood laying down on the prop on one side?
superinflamo is offline   Reply With Quote
Old 07-23-2008, 10:02 PM   #5 (permalink)
ESR/TWS6 Stealth owner
1991StealthR/T's Avatar
Drives: 91' Stealth eSR/T
1991StealthR/T Level 11991StealthR/T Level 1
Sweet, I've been using a piece of wood holding mine up. Is the hood going to be fully opened with the prop in place?
1991 Dodge Stealth R/T - Passion Red - Spun bearing soon to be TTFWD
1985.5 Mitsubishi Starion - California Red - Blown head gasket and sat for 10+ years. - soon to be either running or sitting until the Stealth is done.
1991StealthR/T is offline   Reply With Quote
Old 07-24-2008, 05:41 AM   #6 (permalink)
badass3000's Avatar
Trader Rating: (20)
doesent use the latch.
you have to cut it to fit, so you can have it hold it how ever high you want.
