Old 09-10-2008, 07:45 AM   #31 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
ras463us Level 3ras463us Level 3ras463us Level 3ras463us Level 3
Default Re: holset turbo?
Originally Posted by 3KGTTusch View Post
How do you pipe twins that are split housings? Is there no negatives in doing that?
I'm working on the design of the headers now. I have thought about just dumping the full flow into both port, but first I want to see if I can come up with a design that would allow me to direct the flow to just one side, up to a certain point, and then to both sides at higher RPM levels. This would decrease lag, but I'm not sure what effects it would have on the turbine. I would think that as long as the other port was blocked, the gases couldn't backtrack.
One of the ideas that I'm working with is using wastegates to control the flow to the second port.
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 09-10-2008, 08:04 AM   #32 (permalink)
3KGTTusch's Avatar
Drives: Wishing
3KGTTusch Level 13KGTTusch Level 1
Interesting idea. I would love to see how it turns out.
3KGTTusch is offline   Reply With Quote
Old 09-10-2008, 10:20 AM   #33 (permalink)
Background Guy
Rogue_Ant's Avatar
Drives: '86 Porsche 944
Rogue_Ant Level 1Rogue_Ant Level 1
ras463us,
Check out this thread, these guys have been doing exactly what your describing:
Click
-Rogue
'86 944 Turbo (951)
E-85 Fuel Convert
Powerhaus K27DR Turbo
MAF Translator Pro - MAP Conversion! With Knock Monitoring!
Motronic Enhanements Custom Chip By Hally!
Old Dyno Corrected: 390 RWHP, 417 RWTQ @ +5200ft
See my build-up here!
'02 GSX-R 750
Stock w/ Yoshi slip-on
Rogue_Ant is offline   Reply With Quote
Old 09-10-2008, 10:24 AM   #34 (permalink)
Drives: 95 Green VR-4
Trader Rating: (11)
mess Level 4mess Level 4mess Level 4mess Level 4mess Level 4
Originally Posted by vr4_rider View Post
I think 35 are way bigger then 16gs.
HAve you heard good things or bad things about what inducer?
T
http://www.squirrelpf.com/turbocalc/...&product_id=88
http://www.squirrelpf.com/turbocalc/...product_id=113
I meant the fact that they have billet wheels is pretty cool. From what I understand it makes them some percent lighter so you can run a bigger wheel and get faster spool than say a comparable Mitsu or GT series turbo.
mess is offline   Reply With Quote
Old 09-10-2008, 11:09 AM   #35 (permalink)
VR4Drive92's Avatar
Drives: Black VR4
VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7VR4Drive92 Level 7
Garrett utilizes that EXACT design on the new Acura RDX's. Works very well.
May the Boost be with you....
Look me up on Forza 2 Motorsports Live : A BAD 9 YEAROLD
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
VR4Drive92 is offline   Reply With Quote
