Old 09-09-2008, 08:54 PM   #21 (permalink)
GCtech Industries
GCtech Industries's Avatar
Drives: vr4
GCtech Industries Level 2GCtech Industries Level 2GCtech Industries Level 2
Default Re: holset turbo?
Well If u use twin hx35w with Bulls eye custom .55a/r exhaust housing than that is a different story a 12cm ex is big for twin on a 3L no to mention is divided..
Gil
GCtech Industries is offline   Reply With Quote
Old 09-09-2008, 10:18 PM   #22 (permalink)
3KGTTusch's Avatar
Drives: Wishing
3KGTTusch Level 13KGTTusch Level 1
Whoa old thread.
3KGTTusch is offline   Reply With Quote
Old 09-09-2008, 11:26 PM   #23 (permalink)
Drives: 95 Green VR-4
Trader Rating: (11)
mess Level 4mess Level 4mess Level 4mess Level 4mess Level 4
I have been thinking about trying twin 35's on my 3s when the 3.6L goes in. They seem to compare to 16G's on the flow maps so I'm not sure there would be any gains... I have heard great stuff about their inducers though.
mess is offline   Reply With Quote
Old 09-10-2008, 06:59 AM   #24 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider Level 1vr4_rider Level 1
I think 35 are way bigger then 16gs.
HAve you heard good things or bad things about what inducer?
T
vr4_rider is online now   Reply With Quote
Old 09-10-2008, 07:05 AM   #25 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
ras463us Level 3ras463us Level 3ras463us Level 3ras463us Level 3
I went away from the Holset. Here is what I'm putting on the 3.8 stroker.
These are twin Borg Warner S-200. They have split turbine housings and should spool up nicely with the 3.8L
The last graph shows boost levels for 1200HP on 3.8L with the twin S-200's
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 09-10-2008, 07:25 AM   #26 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Wouldn't you run the graph with 1.9L?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 09-10-2008, 07:31 AM   #27 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
Typically, yes, but the graph is from squirrel performance's virtual calculator, and they allow you to select the number of turbos used. So it does represent 3.8L with 2 turbos. I don't think I would ever run 42PSI of boost, but Its nice to know that the turbos will push it out to 9000 RPM, if I ever wanted to.
Old 09-10-2008, 07:32 AM   #28 (permalink)
3KGTTusch's Avatar
Drives: Wishing
How do you pipe twins that are split housings? Is there no negatives in doing that?
Old 09-10-2008, 07:37 AM   #29 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Oh alright. That calculator is pretty sweet. Can you upload a map if they don't have it?
That was my second question. ~43psi of boost sounds like FUN!
Old 09-10-2008, 07:38 AM   #30 (permalink)
O'Doyle Rules!
D@GE's Avatar
Drives: Miss Daisy
Trader Rating: (10)
D@GE Level 1D@GE Level 1
I have the HX40 with a the bullseye housing, what sucks is I found out the HX40 wasn't from a Cummins diesel so it dosn't have the same turbine wheel, instead it has a larger one so now I'm stuck getting a new turbine wheel and getting it replaced and balanced which isn't cheap
Kyle
I AM CANADIAN......
92 RT/TT guardrail mod
95 RT/TT IT LIVES!!!
D@GE is offline   Reply With Quote
