#1 (permalink) |
Hey guys,
My highbeams are completely out. When I pull the stick, the lights go off completely, but low beams work just fine. Before that problem, I couldn't flash the highbeams with the lowbeams on, but could if the lights were not in the "UP" position. Any ideas? Please help! It's a 91 VR-4 if that helps. Thanks in advance for your help. G |
#3 (permalink) |
The Cop Magnet
judging by the fact your a new user I'm assuming his car is mostly stock.
Might the harnass be loose? and when it pops up the last tab doesnt make good contact. Are any fuses out? Could it be possible theres a short or a corroded contact somewhere in the light switch stalk. Unless you have GTO flashers there shouldnt be a reason your high beams work down rather than up.
![]() 1993 Dodge Stealth ES - 15.2 @ 92.4mph 1986 Peugeot 505 Turbo |
#4 (permalink) | |
I'll find out where the fuses are (I'm a jet mechanic by trade, not a car one) and have a look. Question though, where are the tabs that you are talking about? I'm sure somewhere around the light assembly, but what exactly am I looking for? Thanks again guys! |
