Old 10-03-2007, 12:42 PM   #1 (permalink)
MuDvAyNeDude122's Avatar
Drives: 99'd tt'd 3000gt
Trader Rating: (22)
MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7MuDvAyNeDude122 Level 7
Default Help me figure out why my car is running so rich after swap
i have a 95 base that i just swapped a 91-92 jdm engine into. im using the tt ecu that came with the engine. Everything else is stock. My car has been smoking extremely bad all the time but especially when accelrating. The smoke appears to be white but im not loosing any coolant. I am running extremly rich though, my exhaust smells like gas and i went through $20 of gas in about 20 minutes of driving. I just noticed today that gas is shooting out of the exhaust on the ground. I have pulled the front 3 spark plugs and all 3 had a flat black coating on them so that elimintated a stuck open injector. I datalogged for the first time today but im not sure how to let u guys see my log other than copying over all the graphs to this thread. Im using hhh datalogging software. In the error code section it said previous faults were: code 41, injector circuit. I really dont know what im looking at here, so can anyone tell me if they something wrong? thanks
mods: full 99 conversion, new 99 paint, 18x9 moda r6 wheels, 265/35/18 bfg kdw2 tires, intrax springs, 3sx control arms, twin turbo engine swap, getrag 5speed converted to fwd greddy fmic, prosport gauges, hhh datalogger, ats twin carbon clutch, sx performance fpr, carpc, k/n, ebay downpipe, solid motor mounts, optima yellowtop.
MuDvAyNeDude122 is offline   Reply With Quote
Old 10-03-2007, 01:13 PM   #2 (permalink)
Trader Rating: (22)
Default Re: Help me figure out why my car is running so rich after swap
i just shut off my injectors one at a time, injector 4 didnt cause my rpms to drop like the others did.
Old 10-03-2007, 01:25 PM   #3 (permalink)
3S Motorsports
Drives: 95 VR4
WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6WidowMaker level 6
are you running on 5 cylinders? did you use your stock base air meter? do you have a leak? did you swap the engine harness?
CLICK HERE FOR MONTHLY SPECIAL http://www.3si.org/forum/f1/3s-motor...pecial-435039/
3S Motorsports Is Open For Business
(631) 676-2448
Running the First Pampena 3.5L Stroker
http://www.3smotors.com
-Steve
WidowMaker is offline   Reply With Quote
Old 10-03-2007, 01:31 PM   #4 (permalink)
Trader Rating: (22)
i dont know if im running on 5 cylinders, i am using the stock base mas, but there is no difference between any of them. i dont know if i have a leak, i havnt been able to pressure test, i am using my 95 na harness.
Old 10-03-2007, 02:36 PM   #5 (permalink)
Trader Rating: (22)
i just swapped injector 4 with injector 3 and the problem is still with injector 4. So i guess it must mean wiring. I have a multimeter but im not sure how to check it. Could a wiring problem cause the injector to pour fuel like it is?
Old 10-03-2007, 03:09 PM   #6 (permalink)
Xtreme2k2's Avatar
Drives: 98 SL
Trader Rating: (36)
Xtreme2k2 is an unknown quantity at this point
It certainly wouldnt help
98 Pearl White 3000GT SL *FOR SALE*
Xtreme2k2 is offline   Reply With Quote
Old 10-03-2007, 03:51 PM   #7 (permalink)
Trader Rating: (22)
i just looked at where i soldered in the resistors for the injectors. The resistor for injector 4 was kinda burnt looking, all the electrical tape on the resistor was all shiveled up and burnt looking also. I cut out the resistor and just left the wire disconnected for now and tried starting up the car. It was still pouring gas. So i still have no idea what the problem is.
Old 10-03-2007, 07:27 PM   #8 (permalink)
Trader Rating: (22)
buuump
Old 10-04-2007, 10:35 PM   #9 (permalink)
Trader Rating: (22)
buuump
Old 10-05-2007, 03:47 PM   #10 (permalink)
Trader Rating: (22)
buuump
