Originally Posted by RealMcCoy
I had a couple of possible theories hinging on the answer to my question.... At this point I think your most likely culprit is a sticking valve guide.. I think the valve opens in a normal manner, then hangs slightly and slams shut..
You should be able to easily confirm or debunk my theory by watching the valve operation once you get the cover off...
It could also be something stupid like a collapsed lifter letting the cam slam the valve open, instead of the gradual climb up the opening ramp
Your theory and mine are dead on...glad we think alike
I'm hoping it's just a collapsed, sticking lifter that is so bad that the spring isn't letting the valve return back to its closed position and the piston is actually pushing it back. However, if that were the case, I'd still want to pull the head and replace the sticking valve.
Originally Posted by stealthxtreme4
Subscribed to see what you find out... Definitely interested on that sound. How'd you get the motor to turn over so consistently? lol. I've never seen a starter turn it over like that.
Just pull all of the spark plugs. Without those in, you can't create compression in any of the cylinders.
Originally Posted by jay04
Did u ever remove the valve covers to see anything out of place ie rocker arm?
Not yet. That's the next step in this process and I'm going to try to do it tomorrow, although, this isn't the only thing I've got going on in my life (unfortunately), so I have to prioritize. First, I'm going to pull the rear rocker cover and do a close visual inspection and if I don't see anything then I'm going to drain the oil, remove the oil filter, cut it in half and see if there are any metal chunks in it. I'm also going to pour the oil through a fine screen to see if I can find any more metal shavings.
