#1 (permalink) |
I was taking my trans apart today and as i was reassembling it i wanted to put new silicon down for all places that could leak. I took off that little 4 bolt cover on the tail end of the trans and 4 springs shot out, anyone know what goes where?
Opps! 6speed by the way
Knifed/Shot Peen Forged Crank, Shot Peened Rods w/ ARP Studs, 93mm Ross Pistons, 1mm Valves, 3sx Spring Kit, 99 Lifters, Ported Heads/Lower/Upper Intake/15g Housings/ Manifolds Stillen Dp, Custom 3in Exhaust, Direct Feed Fuel 450cc, Aeromotive FPR, Maft Pro, Front Mount, Spec flywheel Stage 2 Clutch Shifter Bushing Custom Sub Box Alpine Deck Zex kit Repainted Gunmetal 99 Bumper 98 Wing 18 inch gunmetal rims etc etc
http://www.3si.org/forum/showthread....89#post4621589 http://www.3si.org/forum/showthread.php?t=395449 |
#5 (permalink) |
short springs should go on top and bottom holes, longer ones in middle. put trans in nuetral then put the balls in then springs. Look at spring depth when you put them in to make sure they are all sticking out the same amount to make sure.
