Heater giveing me problems - 3000GT/Stealth International Message Center
Old 01-25-2013, 07:37 PM   #1 (permalink)
DEMOSES NY's Avatar
Drives: 95' 3000gt sl
DEMOSES NY is an unknown quantity at this point
Feedback Score: 4 reviews
Mitsubishi Heater giveing me problems
Today after warming up my car i noticed that the heater blower stopped working... at first i thought it was probably a fuse but 10 minutes later i tried again and it worked... heater was working fine until it just shut down again.....this process keeps happening and i have no idea what the problem could be?? Today is first time Ive had this issue.... any theory's, information or answers would be greatly appreciated...ERIK
DEMOSES NY is offline   Reply With Quote
Old 01-25-2013, 08:38 PM   #2 (permalink)
GET A GRIP
Hard AttacK's Avatar
Drives: 91 Stealth TT
Hard AttacK is an unknown quantity at this point
Feedback Score: 15 reviews
Default Re: Heater giveing me problems
i would check for voltage at the blower when it stops. If its getting voltage then I would say bad blower motor. Does it work on any setting hi or low?
Originally Posted by mb3000 View Post
Summary:
Sleeper = excuse for not having the $ to build a well rounded vehicle.
Originally Posted by gatecrasher
DSM owner = king of how fast can i go for $26.
Hard AttacK is offline   Reply With Quote
Old 01-25-2013, 08:56 PM   #3 (permalink)
DEMOSES NY's Avatar
Once it shuts down it doesnt work on any setting... the few times i messed with it , heater came back on after about 10-15 minutes... but only ran for limited time before it shut down... thanks for responding... this problem is killing me its hard to drive with glass fogging up....
Old 01-25-2013, 09:30 PM   #4 (permalink)
GET A GRIP
I would check voltage like I said. I bet its seizing or has corrosion on the electronics.
Old 01-26-2013, 02:29 AM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1
Feedback Score: 3 reviews
Most likely worn out blower motor, OR duct plugged with debris. Its worth your while to pull it and check.
-SP
Old 01-28-2013, 02:10 AM   #6 (permalink)
93Driver's Avatar
Drives: 1993 3000gt SL 5spd
93Driver is an unknown quantity at this point
Feedback Score: 1 reviews
Was the blower motor on mine, so suggest checking that first.
93Driver is offline   Reply With Quote
Old 01-28-2013, 08:37 AM   #7 (permalink)
NeStealth94rt is an unknown quantity at this point
Feedback Score: 2 reviews
Default Heater giveing me problems
Any how to's on how to replace it? Mine just started this yesterday :/
Sent from AutoGuide.com App
NeStealth94rt is offline   Reply With Quote
Old 01-28-2013, 01:31 PM   #8 (permalink)
Nevermind, was way easier then on my old car
Old 01-28-2013, 08:27 PM   #9 (permalink)
93Driver's Avatar
Just in case you change your mind on the *nevermind*:
Blower motor not working, need advice
Good pics & instructions there.
Bigger isn't always Better
Latest Endeavor: Planning big, really BIG
ECU Compatibility Issue
13yr owner of a stock '93 3000gt SL 5spd
2013 replaced: Coils, PTU, IAC || CMC, ECS & Paint
Hates: cold, rain, ice, snow, red lights
Loves: hot sticky pavement, banked corners, downshifting, fresh oil changes, brand new tires
Wants: a girl puppy
Old 01-29-2013, 07:51 AM   #10 (permalink)
I will definitely save that just in case, but I went to the graveyard and pulled a blower motor for 10$ and it fixed my problem! Thanks though
