» Site Navigation
» Related Sites
» Buyers Guide
» Network Links
3si.org is the premier 3000GT/Stealth International Forum on the internet.
Registered Users do not see the above ads.
05-18-2008, 11:49 PM
#1 (permalink )
Regulator...
heat stock rods to press pins in? Engine rebuilders?
Factory says 75-175 lbs to press pins in?
Took a ton and wouldnt budge so i heated the rods a little to press them in.
Was that a no no?
05-19-2008, 01:11 AM
#2 (permalink )
Drunk as a lord
Drives: 1992 Stealth TT
Re: heat stock rods to press pins in? Engine rebuilders?
I've seen a lot of builders do this to old school engines. Hopefully someone with 3/s specific experience will chime in.
Power: 13Ts, 550s, SAFC, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4
12.62 @
111.9 2.0 60 FT Best 1/8th
8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G front brakes
AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/
sideskirts /doorcaps, Scanmaster3, AEM UEGO
05-19-2008, 02:39 AM
#3 (permalink )
Regulator...
yeah ive seen em do it to cast so i dont think theres a prob, just wondering.
05-19-2008, 10:20 AM
#4 (permalink )
'92 VR4
Drives: 1992 VR4
I've pressed in and out well over a hundred pins. I've never had to heat one to get it to move. I have 20 ton press and the gauge is for higher pressures, but I see maybe 300 ~ 400 max (usually when pressing out).
Heating for installing press fit pins has been used for years. When you heated the rod, did you get it hot enough to discolor it? If so, you may have weakened the rod.
05-19-2008, 11:07 AM
#5 (permalink )
Regulator...
I asked Ray and he said heat them to get golden brown but dont go nuts.
Used a handheld torch and got them hot but nothing crazy. Some got a little blue but most were golden brown.
good read here.
Tech Tip: Reconditioning Connecting Rods
05-20-2008, 12:33 AM
#6 (permalink )
It's all stock.
Drives: a de-badged sleeper
My experience has been that a little heat is needed, not too much though. Discoloring the rod is certainly too much.
Handing out reality checks to "500HP Hondas" for 8 years and counting.
'92 Sandstone Grey 3000GT VR-4. K&N filter, Spec 5 clutch, NGK plugs/wires, Custom EBC, Greddy E-manage Ultimate, built 6G74 engine (in progress), Turbonetics ceramic ball-bearing T-70, custom intake/exhaust/intercooler piping (still plumbing those), 24"x12" FMIC, Brembo rotors, Stillen pads, E-bay Ground kit, 2nd gen shifter, HKS SSQV, Denso 660's, twin Walbro fuel pumps, GTO center garnish, eK2 EGR block-off plates, Prosport gauges: [oil press, fuel press, manifold press, oil temp, water temp, volts], Toni's interior LED conversion (still installing), forgot the rest.
'91 Firestorm Red 3000GT VR-4. K&N filter, eK2 poly engine mounts, Seattle Short Shifter, custom MBC, Spec 3+ clutch, Forged crankshaft, Tein S-Tech springs (front only), DNP Y-pipe, TD04H-13T's (with 13T wastegates), amber taillights, gutted pre-kitties, eK2 EGR block-off plates, Prosport gauges: [oil press, manifold press, fuel press, water temp], Megan Racing downpipe, Borla exhaust, NGK plugs, MSD wires, Greddy type-S BOV, Greddy E-manage Ultimate, RC 550 injectors, Denso "Supra" fuel pump, MSD DIS-4, Brembo rotors, Stillen pads, forgot the rest.
'90 Fiji Blue 300ZX TT. Stillen front bumper/nose-panel/wing/control arms/sway bars, Greddy intake/exhaust/clutch/fuel injectors, Super Autobachs strut bars, Brembo brakes, Energy Suspension bushings, Tokico shocks, JWT ECU chip, Bomex rear bumper, Nismo gound kit, NGK plugs, IPS short shifter, Custom interior, forgot the rest.
'92 Black MR2. Wife's car. K&N filter on a custom cold-air intake, some interior stuff.
