hatch leaking! - Page 2 - 3000GT/Stealth International Message Center
Old 02-22-2011, 02:51 PM   #11 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Darksurfr is an unknown quantity at this point
Feedback Score: 16 reviews
Default Re: hatch leaking!
I have the same issue as my hatch is rusting out and most of the guys I know have this isssue. There are 2 things i suspect but cant seem to fix. If you pull the rear window glass lower seal off there are clips that might allow water to build up around them and seep in. Now this being said its because the seal no longer stops the water from going in and it just allows it to collect by these through plastic clips.
I decided to silicone around them in hopes that this would solve the issue as well as silicone around the base of the spoiler. To no evail. If I let the car sit level when it rains the water builds up inside the rear plastic cover and rusts the wiper motor. lift the trunk lid and it all pours out into the drains and some into the rear carpet. I dont have water building up in the trunk but I know with no rear plastic it would. My rear hatch seam is going to rust out shortly and I can only think to replace it and find the problem then. No idea. I contimplate filling the replacement with foam. This would also be a reason to get a fiberglass one or carbon fiber. Not because it will help with weight at all but it wont rust out.
any updates would be awesome.
Darksurfr is offline   Reply With Quote
Old 02-23-2011, 06:37 AM   #12 (permalink)
typetr's Avatar
typetr is an unknown quantity at this point
Feedback Score: 0 reviews
I've got this problem as well :S. if i open the boot a small waterfall soaks what was the boot. Luckily for me its all stripped so I have little need to open it and i can wipe it up as its falling on bear metal. Although it would be nice not to have a small lake mulling around :S.
Project Blog: http://www.typetr.co.uk - my baby for sale £1250
Twitter: Type_TR
Facebook: "Typetr Tom Riley"
typetr is offline   Reply With Quote
Old 02-23-2011, 11:34 PM   #13 (permalink)
andronitrate's Avatar
Drives: 97 vr4
andronitrate is an unknown quantity at this point
Feedback Score: 3 reviews
its crazy how many people have the same issue but cant figure it out......I guess ill just keep throwing the cover on it when it rains
funny gif Pictures, Images and Photos
andronitrate is offline   Reply With Quote
Old 02-24-2011, 10:20 AM   #14 (permalink)
Darksurfr's Avatar
not acceptable! find it and fix it. God knows these cars didnt come like this from the factory... something needs to be fixed and it calls to me! (but i cant find it)
Old 02-26-2011, 03:42 AM   #15 (permalink)
ely
ely's Avatar
Drives: 95TT - 04 957 PCS
ely is an unknown quantity at this point
Feedback Score: 2 reviews
had the same issue.
the rear wiper engine got rusted pretty bad also.
Now, I've removed the wiper assembly + the spoiler, and filled the holles.
didn't took the car out to see what if the water is still there as my car is under knife and also it snowing
now, from these holes to the back of the hatch, I suspect the water movement and because there isnt any drain area there, here it comes rust.
I'm thinking that a rear fiber glass hatch will solve this
'99 Front Bumper, Philips HID's, Infinity Kappa 693.7I & Kappa Perfect 6.1 & Kappa Perfect 12VQ, Dietz Power Cap 1F, Pioneer HU, 2x Kenwood Amplifiers
Apexi AVC-R, K&N AirFilter, Supra pump hotwired, Tein Flex Coilover Suspension Kit, .... more to come
....and yes BORLA, is romanian.
www.ToolMan.ro
ely is offline   Reply With Quote
Old 11-21-2012, 02:12 PM   #16 (permalink)
cusmar45's Avatar
Drives: A bastard
cusmar45 is an unknown quantity at this point
Feedback Score: 5 reviews
bringing this back... have the same issue. Did ANYONE find out where it could be comming from?
cusmar45 is offline   Reply With Quote
Old 11-21-2012, 02:17 PM   #17 (permalink)
NC Insurance Agent
jbeard1's Avatar
Drives: 1995 3000GT
jbeard1 is an unknown quantity at this point
Feedback Score: 1 reviews
Ill take this as like a new thread... Did you check your plugs under the hatch? This was my problem, unfortunately I was given no warning until I went to work one morning after a stormy night, and discovering 2-3 inches of water sitting in my floorboard. This is a lot of times the problem. Probe the plugs with something straight, then shoot a water hose down all the plugs. Let me know how this works.
jbeard1 is online now   Reply With Quote
Old 11-21-2012, 02:21 PM   #18 (permalink)
cusmar45's Avatar
Drives: A bastard
plugs are open... cleaned them out and it flows no problem. The water comes from inside the hatch itself. Open the hatch and water comes pouring out. while the channels and plugs are bone dry.
Old 11-21-2012, 03:43 PM   #19 (permalink)
Grandpa Poser's Avatar
Grandpa Poser is an unknown quantity at this point
Water in the back seats could be sunroof seal or the two electrical plugs.
Water in the lower hatch/tray/wiper motor cover could be.
Power connections.
Hatchglass seal, in particular lower/side/corner/garnish area (water runs from there on mine)
Hatch anti-rattle stop blocks. (these seem to act like a dam and water gets deep enough to seep in at window corner seal)
Luck
When life throws you a curve......Drive Baby, Drive.
Grandpa Poser is offline   Reply With Quote
Old 11-21-2012, 05:14 PM   #20 (permalink)
[IMG][/IMG]
edit, my leak here
