hatch leaking! - 3000GT/Stealth International Message Center
Old 02-21-2011, 03:49 PM   #1 (permalink)
andronitrate's Avatar
Drives: 97 vr4
andronitrate is an unknown quantity at this point
Feedback Score: 3 reviews
Default hatch leaking!
first off I haves searched every thread about this and there is alot! I have checked my seal, cleaned out my drain's, and had a friend spray with hose while I watched from inside with plastic panel off. It seems to only come in when it rains?? when I back out of my driveway I can see it pouring in the hatch(passenger rear). cant tell where its getting in at? I have my rear seats out and the passenger gets about 2 in of water overnight. Almost every thread about this ends with just giving up. I hope someone who has fixed this will shed some light here? I was thinking maybe the wiper but doesnt look to be coming from there.
funny gif Pictures, Images and Photos
andronitrate is offline   Reply With Quote
Old 02-21-2011, 04:11 PM   #2 (permalink)
Drives: 97 vr4
Default Re: hatch leaking!
hear is a video showing a couple rust spots and how my hatch doesnt seem to line up quite evenly
Old 02-21-2011, 06:06 PM   #3 (permalink)
Senior **i.e. OLD** Member
OhioSpyderman's Avatar
Drives: Back and Forth :)
OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3OhioSpyderman Level 3
Feedback Score: 57 reviews
Here's the first thing that comes to mind.
Seeing the rust at the very rear end of the hatch makes me wonder if the water is coming in around where the spoiler is attached to the hatch? (seems that the water may run down from the hatch and try to exit at that rear seam....). The water coming straight down would be worse than spraying with a hose (unless you concentrated it right on that area...).
I can't imagine it would be too tough to remove that center section and inspect that area?
Again, just shooting from the hip....
Bob.
95 Caracus Red Spyder VR4
Cianci FG Viper Hood/Aerocatch Pins
Quad Carbon Fiber Tipped Borla Catback
Stock 18" 6 Spoke Chromies
K&N FIPK
Indiglo Gauges
JimVR4's Remote Start/Top Op Computer
92 Wheat Beige Metallic Stealth TT..Winter DD!!
OhioSpyderman Short Shifter (in both!!!)
SBC-iD Boost Controller (in both!!!)
Oldest son - 94 Danube Blue VR4
Middle son - 93 Panama Green VR4
OhioSpyderman is offline   Reply With Quote
Old 02-21-2011, 06:16 PM   #4 (permalink)
Drives: 97 vr4
Bob.
just pulled the plastic caps off the spoiler bolts and there rusty so ima hafta investigate!
Old 02-21-2011, 06:19 PM   #5 (permalink)
2 3 4 5 6
Bob.
Old 02-21-2011, 06:21 PM   #6 (permalink)
-Driftus Maximus-
Nationalmilkman's Avatar
Drives: '92 Stealth ES
Nationalmilkman is an unknown quantity at this point
Feedback Score: 4 reviews
I didn't have water leaking in but when the back glass came out there was rust under the window sealant at the bottom of the glass. May be the same thing with yours?
Nationalmilkman is offline   Reply With Quote
Old 02-21-2011, 06:24 PM   #7 (permalink)
Another GOOD call (although with the 4 non Spyder's we've owned, we've not seen this issue....or for that matter, the OP's issue either...)
+ rep for you sir!!!
Bob.
Old 02-21-2011, 07:04 PM   #8 (permalink)
Drives: 97 vr4
well I pulled the spoiler off and there is no way water could get in that way, put some sealant down just for good measure, took the rear wiper out and sealed it also....I guess ill find out if it worked next time it rains
Old 02-21-2011, 07:15 PM   #9 (permalink)
Just tried to help....
Hope it's solved
Bob.
Old 02-21-2011, 07:19 PM   #10 (permalink)
Drives: 97 vr4
Hope it's solved
Bob.
