Old 08-12-2008, 02:03 PM   #1 (permalink)
One Sinister Motha Sucka!
Sin'sVr4's Avatar
Drives: 91 VR4/94 Wrangler
Trader Rating: (9)
Sin'sVr4 Level 2Sin'sVr4 Level 2Sin'sVr4 Level 2
Default has anyone installed this PCV valve?
Mitsubishi Twin Turbo 3000gt VR4 Krank Vent PCV valve replacement
I think my pcv valve is sticking (dip stick popped out) and was wondering if anyone has done this and if it works?
MIke
Still Waiting for her to get on the road!! $$$ and counting!!!!
Sin'sVr4 is offline   Reply With Quote
Old 08-12-2008, 02:06 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: has anyone installed this PCV valve?
You mean Krank Vents? Do a search, many people have used and discussed them in the past.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 08-12-2008, 06:41 PM   #3 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
i would do a pressure test on your car..and i know someone who can do it for ya..wink wink!
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 08-12-2008, 08:44 PM   #4 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6
I looked into these and PCVs a lot and my PERSONAL opinion is to just use a known good stocker.
I've heard (remember I've only heard this, no facts) that they cause more harm than good because of the constant vacuum in the crankcase. After hearing this I started seeing how some people only use one valve which really does the same thing as the stock system and realized the stock setup works pretty well (when functioning). A lot of people also use Supra PCV valves because they're supposedly stronger. I've even seen these sold on eBay as "generic krankvents".
1994 3000GT SL - Old Daily Driver SOLD
Custom Paint, Full Custom Exhaust, etc.
1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation
Go: eBay Tanabe Concept G Blue Replica TBE, Metal Evo DV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft
Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge
Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc.
Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals
HLxDrummer is offline   Reply With Quote
Old 08-12-2008, 11:23 PM   #5 (permalink)
Drives: 93 3000
paul_3000gt@yah is an unknown quantity at this point
hey that kits makes it so that the pvc only goes one way so theres less pressure in the cylinders so you dont have lots of pressure in the crank case ive also hear it makes your car stop smoking if it does or reduce the amount
Paul-GT-
93 Base 3000GT limo tint,60K,power slot rotors,NGK,maxinal test pipe and single shot,3sx down pipes,K&N
weight redution-fogs,front and rear wiper bottle, licence plate bracket,rear wiper motor,antenna,tow hooks.
To come- spot weld car, deft hood,coil overs
KENDWOOD,Diamond HEX,Infinity KAPPA,Rockford amps, Lightning audio strike dual coil 4 ohm sub 10''
paul_3000gt@yah is offline   Reply With Quote
Old 08-13-2008, 01:27 PM   #6 (permalink)
Sin'sVr4's Avatar
Trader Rating: (9)
stop smoking? how?? wont that do the same if you replace a defective pcv with a new stock replacement?
Old 08-15-2008, 09:15 AM   #7 (permalink)
Drives: 93 3000
becuase if theres a leak in on of your piston rings where oil leaks threw theres less of the harmfull pressure against it so it doesnt smoke as much.
I read that on a website that made those kits of a 3000.
