#1 (permalink) |
One Sinister Motha Sucka!
Mitsubishi Twin Turbo 3000gt VR4 Krank Vent PCV valve replacement
I think my pcv valve is sticking (dip stick popped out) and was wondering if anyone has done this and if it works? MIke
Still Waiting for her to get on the road!! $$$ and counting!!!!
#3 (permalink) |
Oh SNAP!!!
i would do a pressure test on your car..and i know someone who can do it for ya..wink wink!
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine** Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!! 1st car with the Enkei RZ-5 18''x8.5'' *534x306* ![]() 1994 Dodge Stealth R/T TT~Pearl Yellow |
#4 (permalink) |
I looked into these and PCVs a lot and my PERSONAL opinion is to just use a known good stocker.
I've heard (remember I've only heard this, no facts) that they cause more harm than good because of the constant vacuum in the crankcase. After hearing this I started seeing how some people only use one valve which really does the same thing as the stock system and realized the stock setup works pretty well (when functioning). A lot of people also use Supra PCV valves because they're supposedly stronger. I've even seen these sold on eBay as "generic krankvents".
![]() 1994 3000GT SL - Old Daily Driver SOLD Custom Paint, Full Custom Exhaust, etc. 1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation Go: eBay Tanabe Concept G Blue Replica TBE, Metal Evo DV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc. Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals |
#5 (permalink) |
hey that kits makes it so that the pvc only goes one way so theres less pressure in the cylinders so you dont have lots of pressure in the crank case ive also hear it makes your car stop smoking if it does or reduce the amount
Paul-GT-
93 Base 3000GT limo tint,60K,power slot rotors,NGK,maxinal test pipe and single shot,3sx down pipes,K&N weight redution-fogs,front and rear wiper bottle, licence plate bracket,rear wiper motor,antenna,tow hooks. To come- spot weld car, deft hood,coil overs KENDWOOD,Diamond HEX,Infinity KAPPA,Rockford amps, Lightning audio strike dual coil 4 ohm sub 10'' |
