Old 07-01-2008, 08:51 AM   #41 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Re: Greddy porfec B spec 2...What is everyones settings and mods???
LOL
http://greddy.com/img/PHP/products/pdf/682.pdf
I updated my post, fyi, set was 45 not 40 that got me 15psi.
R.I.P.
Old 07-01-2008, 12:05 PM   #42 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Drives: Expensive Biatch!!!!
Trader Rating: (14)
Sin'sVr4 is an unknown quantity at this point
Originally Posted by aaronatstate View Post
Seriously dude, read the manual.
in the owners manueal it does not say to hold down the select button. It says once turned off, with in 2 sec press the mode button twice. Im not an idiot. Just reading what the MANUEL says. Thanks tho, I will try that
There is no such thing as LUCK...Luck is when opportunity meets prepardness
Sin'sVr4 is offline   Reply With Quote
Old 07-01-2008, 07:20 PM   #43 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (9)
aaronatstate Level 1aaronatstate Level 1
OK dude, since you obviously can't read the manual, I will show you where it says the controller has to be off (not the car, the controller), and then you can change the pressure mode, where you have to HOLD the select button. Read the manual, it says exactly what to do.
January 2009 - ROTM
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 07-01-2008, 07:34 PM   #44 (permalink)
Spartan for Life!
Trader Rating: (9)
LOL
I posted that already
Old 02-08-2009, 11:49 PM   #45 (permalink)
Jason61991's Avatar
Jason61991 is an unknown quantity at this point
Low - (Extremely Stable 7psi)
Set: 22
Gain: 12
Set Gain: .38
High - 12 psi (Unstable)
Set: 61
Gain: 33
Set Gain: .87
Jason61991 is offline   Reply With Quote
Old 02-13-2009, 09:15 PM   #46 (permalink)
Jason61991's Avatar
New Settings - (Both are extremely stable)
Low - 7 psi
Set - 22%
Gain - 12%
S. Gain - .38
High - 12.5 psi
Set - 59%
Gain - 6%
S. Gain - .64
Old 02-24-2009, 11:45 PM   #47 (permalink)
little Boss man
iguana's Avatar
Drives: 93 VR4
Trader Rating: (10)
iguana is an unknown quantity at this point
gain 35%
set gain .90
set 52%
hits 1.30 boost ~18psi
Longwood Florida
DR500 turbos, ProfecB Spec II, No cats, Modified Stillen DP, 3" pipe with dual N1 cans, Walbro FP, TurboXS BOV, Stillen pads, Rotors, DXD clutch, Fidanza flywheel. MAFT, bigass KNN filter, 550cc injectors. 3SX lower mounts. Tien S springs. Jays93VR4 rear upper arms. Aluminum intake pipes, 3SX light pulley.
Still to install, Pre cat eliminators.
iguana is offline   Reply With Quote
