Old 06-30-2008, 02:54 PM   #31 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default Re: Greddy porfec B spec 2...What is everyones settings and mods???
Originally Posted by Sin'sVr4 View Post
about 11.9-12.3 in the higher rpms.
You're seeing ~12.0 AFR under load at high rpms? Fail. Are you logging knock?
Sounds like you still need to adjust your SAFC some more before you start worrying about the EBC.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 06-30-2008, 03:48 PM   #32 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Drives: Expensive Biatch!!!!
Trader Rating: (14)
Sin'sVr4 is an unknown quantity at this point
Clint
this is only my first day tuning the safc. I will be messing with it more here soon. I need to be at 11.2 after 5000 rpm correct?
There is no such thing as LUCK...Luck is when opportunity meets prepardness
Sin'sVr4 is offline   Reply With Quote
Old 06-30-2008, 04:34 PM   #33 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
You should be aiming for low 11s under load. It's not a matter of rpm. What did you use for a base correction? Generally, the base correction will give you a richer mixture than necessary.
Again, are you logging knock? In addition to the number on your wideband, you should be logging knock and timing.
Clint
Old 06-30-2008, 05:08 PM   #34 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
I'm using my logger, mmcd on my palm. Trying to figure it out. I know that i have 2-3 knock a couple times at around 4300rpm. once it spiked to 28? only once tho.
Old 06-30-2008, 08:03 PM   #35 (permalink)
Rock Chalk, Jayhawk
PhillipTT's Avatar
Drives: 92 Stealth TT
Trader Rating: (8)
PhillipTT is an unknown quantity at this point
I can't log boost atm but bjmsam posted a great solution, if your boost controller happens to have a MAP output (like the AVC-R).
I have a Profec B spec 2
I guess I should just have a friend check or pick up a GM MAP sensor and log with MMCd.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
PhillipTT is offline   Reply With Quote
Old 06-30-2008, 08:23 PM   #36 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (9)
aaronatstate Level 1aaronatstate Level 1
That 60 setgain seems awfully high.
If you get fuel cut, you know. It's like hitting a brick wall.
On totally stock fuel, I don't even know what the limits are. I know I could run 15psi with stock injectors (130-140% IDCs), but I had a hotwired walbro 255.
Actually it seems low if hes in psi mode, then it would only be 6.0psi. Come on you should know this
January 2009 - ROTM
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 06-30-2008, 09:07 PM   #37 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
i tried to get it into to psi mode and it didnt work.
1.power off, within 2 sec, press mode 2 times???
didnt work. How do I get it to psi mode? I dont know wtf kPa means or how to read it??
Old 06-30-2008, 09:38 PM   #38 (permalink)
Spartan for Life!
Trader Rating: (9)
Its pretty easy. 1.00kpa = 14.7psi.
Make sure you just turned the boost controller off, not the whole car, the boost controller off just means there hi/lo indicator isnt there.
EDIT: Here is how to do it. Hold down the select button for 2 seconds. This turns the boost controller off. Once its off remove all fingers from buttons. Next press the select button again, while holding the select button within 2 seconds press the mode button twice. What is so hard about that to understand?
Old 06-30-2008, 09:42 PM   #39 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
how do you change it to psi tho?
Old 07-01-2008, 12:50 AM   #40 (permalink)
Spartan for Life!
Trader Rating: (9)
Seriously dude, read the manual.
