Old 06-28-2008, 10:56 PM   #21 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Drives: Expensive Biatch!!!!
Trader Rating: (14)
Sin'sVr4 is an unknown quantity at this point
Default Re: Greddy porfec B spec 2...What is everyones settings and mods???
ok cool. Just read it. i do have the inst manuel. I am at work and needed to read it. I think after reading this i understand the settings more now. I will let you know what happens.
oh, by the way, will the boost guage vac line being basically cut off have an ill effects on the way the boost controller operates?
The line that came with the guage was basically fused together because of the turbos heat. hmmm
There is no such thing as LUCK...Luck is when opportunity meets prepardness
Sin'sVr4 is offline   Reply With Quote
Old 06-29-2008, 02:39 AM   #22 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (9)
aaronatstate Level 1aaronatstate Level 1
If its the vacuum line going to the Profec, yes. If its the vacuum line going to a boost gauge, no.
January 2009 - ROTM
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 06-30-2008, 01:40 AM   #23 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
k went and did some test runs and it seemed to be boosting at 10psi. I'm at 55% set, 15% gain, and 60 set gain? My fuel is basically stioch thru all rpms lo and hi ne points on my safcII. Just need to figure out how to tweek it. I am going to just bring it to the dyno and have them set it up for me.
Old 06-30-2008, 09:07 AM   #24 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Just played with my car over the weekend as I put in my 550s.
I see 15psi with Set 45, Gain 5, SetGain 10.
I see 17-18psi with set 55, gain 10, setgain 15.
R.I.P.
Old 06-30-2008, 12:52 PM   #25 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
i think im getting fuel cut as i havent installed my 560's or walbro.
Old 06-30-2008, 12:58 PM   #26 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
That 60 setgain seems awfully high.
If you get fuel cut, you know. It's like hitting a brick wall.
On totally stock fuel, I don't even know what the limits are. I know I could run 15psi with stock injectors (130-140% IDCs), but I had a hotwired walbro 255.
Old 06-30-2008, 01:08 PM   #27 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
Ya, it would go then just like stutter. That fuel pump can push so much more fuel thatn the stocker. Maybe Ill do that this weekend
Old 06-30-2008, 01:38 PM   #28 (permalink)
Rock Chalk, Jayhawk
PhillipTT's Avatar
Drives: 92 Stealth TT
Trader Rating: (8)
PhillipTT is an unknown quantity at this point
I see 15psi with Set 40, Gain 5, SetGain 10.
Are you holding those boosts all the way to redline? Do you log boost somehow?
I've been playing with mine some more, too. I'm having trouble on the street trying to look at the gauge, the road, and the tach. I may have to look into logging boost.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
PhillipTT is offline   Reply With Quote
Old 06-30-2008, 01:48 PM   #29 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: Crutches
Trader Rating: (80)
That almost sounds like spark blowout. Do you get real rich when you feel it stutter?
I can't log boost atm but bjmsam posted a great solution, if your boost controller happens to have a MAP output (like the AVC-R). It holds both boosts till redline. For the high boost, when it was at 60 set and 5 gain (with 15 setgain) it would spike at 18.5 and hold 17 to redline. Now it's spiking maybe 17.5 then holding 17 to redline. My butt dyno is broken, but it sure did run through 3rd gear more quickly with 550's and 17psi (even with a ridiculously rich 10.0 AFR) than it did with stock 360's and 15psi (with stock 11.2 down to 10.8 AFR). I can never tell how fast a car is when I'm driving it.
Old 06-30-2008, 01:53 PM   #30 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
about 11.9-12.3 in the higher rpms. still tuning it tho, only 1st real time out yesterday trying to get it all straight. tell you what tho, the sob runs better, just need to put the injectors and pump in. runs, 14.6-14.8 all thru the lo ne points. more lean in the higher so i think i am getting comforatable with the safcII.
the greddy tho is gonna be the death of me! friggin thing irritates me.
