Old 06-27-2008, 07:56 PM   #11 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Drives: Expensive Biatch!!!!
Trader Rating: (14)
Sin'sVr4 is an unknown quantity at this point
Default Re: Greddy porfec B spec 2...What is everyones settings and mods???
What is your limiter set at? It says 4% less than your Set. If I start my set at 30 does that mean 26%? I have seen a bunch of people with 4% limiter
There is no such thing as LUCK...Luck is when opportunity meets prepardness
Sin'sVr4 is offline   Reply With Quote
Old 06-27-2008, 08:01 PM   #12 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (43)
vr4_rider is an unknown quantity at this point
I have 13T's and 560cc and FMIC.
My settings are:
Set @ 35%
Gain @ 5
Set Gain @ is at 100
At that Set and Set Gain, I get 12psi.
Any comments on my settings?
Also, my Gain can only be as low as 5....is that normal?
T
vr4_rider is online now   Reply With Quote
Old 06-28-2008, 01:44 PM   #13 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
I was trying to set up my boost controller and I was totally lost. I thought I could handle it but nope. I got the fuel controller good now, but seems like i am only maxing my boost at 5 psi? The vac line that came with my boost guage was like squishy line, and when it got hot it just melted and stuck together. looks like when you suck all the air out of a tube and it is pinched together.
I bought good line yesterday so maybe that will help. I want to boost around 15 psi can anyone give me a step by step direction to set mine up?
Example
step 1. push select lo, then set your set
step 2. dial in your # and push the knob in...
i need that kinda stuff broken barney style.. Please guys need this working right by monday, going to hte paint guys and need to be able to get it there.
100 set gain? wow isnt that really high?
Old 06-28-2008, 03:48 PM   #14 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (9)
aaronatstate Level 1aaronatstate Level 1
Example
100 is for the psi setting, it comes stock set in bars. My set gain is at 120 or 12.0psi. Every car is different so you just need to go out and set it to what you need. For example my settings are different then what most people have. I have no boost leaks, vacuum leaks, and my engine and turbos are in great condition.
Set 63%
Set Gain 12.0 (120)
Gain 10%
This gets me ~14.5psi with little to no spike. Do all of your testing in 3rd gear. Read these 2 things and go out and try it again.
The Pansy Patrol » Greddy Profec B Spec-II: Tuning Tips for 3/S owners
http://www.alamomotorsports.com/gred...EC_B_SPEC2.pdf
January 2009 - ROTM
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is online now   Reply With Quote
Old 06-28-2008, 07:20 PM   #15 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
how do i change the settings from kpa to psi or vice versa? It seems like when i dial the settings to the appropriate setting i want it at and push the knob it doesnt save?
so, I go to set, dial 60% then push the knob right and then hit mode to go to the next setting like gain?
Old 06-28-2008, 07:40 PM   #16 (permalink)
Rock Chalk, Jayhawk
PhillipTT's Avatar
Drives: 92 Stealth TT
Trader Rating: (8)
PhillipTT is an unknown quantity at this point
Did yours not come with an instruction manual? Google it and download the manual. It will tell you how to switch and adjust everything.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
PhillipTT is offline   Reply With Quote
Old 06-28-2008, 08:40 PM   #17 (permalink)
Spartan for Life!
Trader Rating: (9)
Did you even read the links I posted? One of them was the instruction manual which will tell you how to set everything. Read it, try it, then come back and ask questions.
The second link I posted was the instruction manual, I guess he didnt read it.
Old 06-28-2008, 08:43 PM   #18 (permalink)
Spartan for Life!
Trader Rating: (9)
My settings are:
Set @ 35%
Gain @ 5
T
Gain only goes down to 5, so its normal. And the settings are different for every car. Set it to what gets you what you want and go My set is at 10%.
Old 06-28-2008, 10:30 PM   #19 (permalink)
I GOT BOOST YAY!!!!
Sin'sVr4's Avatar
Trader Rating: (14)
it wouldnt open for me
Old 06-28-2008, 10:50 PM   #20 (permalink)
Spartan for Life!
Trader Rating: (9)
give it time, it takes a few seconds to open.
