Old 09-22-2008, 10:10 AM   #1 (permalink)
Self-proclaimed Expert
7eddiedoowop7's Avatar
Drives: while tuning
7eddiedoowop7 is an unknown quantity at this point
Default General scanmaster questions, datalogging
I tried searching. I found that USB>Serial cables don't work. I see people using the same setup as me...but I cannot find how they are hooking this up.
I see many people using the scanmaster 3 and a palm pilot to data log. I am just wondering what type of cables are being used? Everyone makes it sound simple...but the scanmaster 3 has a rs232 connection and cable, but palm does not. At least older ones, like my m505. Models similar to mine only have the "cradle" connection on the bottom of the palm unit...Nothing supplied with the palm nor the scanmaster allow for the two to be hooked up.
Can anyone explain how I can get started logging?
Again, I have a scanmaster 3, installed, reading the ecu. I have a palm m505 with a cradle, which has a USB and power connection. People have said that a USB>Serial cable does not work, so although I don't know exactly what cable they are talking about, I'd assume that one won't work.
Thanks,
Eddie
1992 Glacier White Pearl 3000GT VR-4:
DR 16t's | ARC-2 | 550's | hotwired walboro 255 | Spec III clutch / Fidanza flywheel | AEM tru-boost / AEM wb o2 / Scanmaster | Needs a tune...
7eddiedoowop7 is offline   Reply With Quote
