Old 05-09-2008, 08:55 AM   #21 (permalink)
Drives: 93 VR-4
neverenoughhp is an unknown quantity at this point
Default Re: Gas Mileage?
Turbo, 5 spd, 375 whp, 26mpg hw at 75mph, guessing 15 city. Of course these numbers go to shit if I do anything more than baby it. I need to put the front aero cover back on to help. I removed the motor and arms for weight reductions but still need the cover for aero. I am also going to do something in the rear; either holes in the side of the bumber cover or fab a cover...
neverenoughhp is offline   Reply With Quote
Old 05-09-2008, 08:59 AM   #22 (permalink)
Drives: 95' 3000GT SL
NTX_3kGT is an unknown quantity at this point
I get 18 city and 20 highway. And thats driving conservatively. How are you guys, and girls, with TTs getting 25 - 30? Something must be wrong with my car.
1995 Mitsubishi 3000GT SL
Mods:
Mobo Shifter and E-brake boots - red and black
NTX_3kGT is online now   Reply With Quote
Old 05-09-2008, 09:02 AM   #23 (permalink)
GTCUL8R
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 1Polygon Level 1
I get an average of 24 in the TT combined city/highway.
That's if I keep my foot out of it.
Polygon is offline   Reply With Quote
Old 05-09-2008, 09:06 AM   #24 (permalink)
fastlanedriver's Avatar
Drives: 91 dodge stealth tt
Trader Rating: (-2)
fastlanedriver is an unknown quantity at this point
ok i might have a problem then i checked mine the other day it it was 8mpg. i drive mostly in town sometimes the freeway. wtf is going on? any help? i see all you guys have 10 20 up
fastlanedriver is offline   Reply With Quote
Old 05-09-2008, 09:21 AM   #25 (permalink)
VR3.9's Avatar
Drives: 91 VR4
VR3.9 is an unknown quantity at this point
yea I pretty much hate you all.
edit: except you fastlane
VR4 10-12 200 to a tank.
I need some help or an a couple of oil wells.
VR3.9 is offline   Reply With Quote
Old 05-09-2008, 10:50 AM   #26 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
19 in town daily driving. Up to 28 on the highway with the fuel leaned out and no AC running.
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior.
JeffWVR4 is online now   Reply With Quote
Old 05-09-2008, 11:32 AM   #27 (permalink)
Master_O_Trunks's Avatar
Drives: 95' 3000GT Base
Master_O_Trunks Negative 2
I can get between 18-20 city driving, since thats where I use it the most. Mainly cause my cluth is slipping im getting that mpg lol! But yeah 25mpg will be nice once I get my car in a very healthy condition! I currently filled my tank to full, I got about 105 or so miles for that first 1/4 so im guessing I should be able to get 400-430 for the full tank.
And I don't baby my pedal, I usually shift at about 3k-4.5k RPM, going 40-60mph in the city FTW! lol!
Master_O_Trunks is offline   Reply With Quote
Old 05-09-2008, 11:41 AM   #28 (permalink)
J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7
I'm getting great mileage because I'm in 5th at speeds of 40 the car is barley over idle at that point.
Helps out a lot. I just baby her and drive for good mileage when in traffic, there is no need to waste gas when you can't have fun.
--3Si# 592--ROTM Dec. '07--www.IPSMotorsports.net--www.3SX.com
J-Groove is online now   Reply With Quote
Old 05-09-2008, 11:55 AM   #29 (permalink)
1320VR4's Avatar
Drives: 93 Dodge Stealth ES
Trader Rating: (11)
1320VR4 is an unknown quantity at this point
same here, low end power is a mad advantage :-D
The Mitsubishi 3000GT represents a case study in technological overkill. Whilst some rivals used a technological sledgehammer to crack a nut, an apt image for the 3000GT would be a small peanut perched atop a hundred-megaton thermonuclear device.
1993 Dodge Stealth ES - 15.2 @ 92.4mph
1986 Peugeot 505 Turbo
1320VR4 is online now   Reply With Quote
Old 05-09-2008, 01:38 PM   #30 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
I get 17-18 mpg in mixed environment, using 15W40. and I cant drive it slow. I tried, and actually was doing quite well for the first 50 miles but than I couldn't take it anymore. on highway I'm on 30% thrt pos and 270Hz of air flow. is that normal?
1993 3000GT VR4.
________________________
Was bored, had to do stuff:Free_boost, cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, 0.025'' gaped spark plugs, Datalogger, S-AFC.
Working on: Driver mod, Clutch, 560cc, AEM TruBoost.
E85 powered VR4 coming soon...
Wanted: Wideband A/F, A-Pillar Gauge pod.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
