#21 (permalink) |
1st NG08 / 2nd NG07 Drags
Turbo, 5 spd, 375 whp, 26mpg hw at 75mph, guessing 15 city. Of course these numbers go to shit if I do anything more than baby it. I need to put the front aero cover back on to help. I removed the motor and arms for weight reductions but still need the cover for aero. I am also going to do something in the rear; either holes in the side of the bumber cover or fab a cover...
#22 (permalink) |
I get 18 city and 20 highway. And thats driving conservatively. How are you guys, and girls, with TTs getting 25 - 30? Something must be wrong with my car.
1995 Mitsubishi 3000GT SL
![]() Mods: Mobo Shifter and E-brake boots - red and black |
#26 (permalink) |
Certified Car Nut
19 in town daily driving. Up to 28 on the highway with the fuel leaned out and no AC running.
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy ![]() Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PwerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior. |
#27 (permalink) |
I can get between 18-20 city driving, since thats where I use it the most. Mainly cause my cluth is slipping im getting that mpg lol! But yeah 25mpg will be nice once I get my car in a very healthy condition! I currently filled my tank to full, I got about 105 or so miles for that first 1/4 so im guessing I should be able to get 400-430 for the full tank.
And I don't baby my pedal, I usually shift at about 3k-4.5k RPM, going 40-60mph in the city FTW! lol! |
#28 (permalink) | |
Helps out a lot. I just baby her and drive for good mileage when in traffic, there is no need to waste gas when you can't have fun. ![]() -John
#30 (permalink) | |
Driving While Ukrainian
I get 17-18 mpg in mixed environment, using 15W40. and I cant drive it slow. I tried, and actually was doing quite well for the first 50 miles but than I couldn't take it anymore. on highway I'm on 30% thrt pos and 270Hz of air flow. is that normal?
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump. Working on: Driver mod. E85 powered VR4 Dream car: F40 (LM) Quote:
