Full-car build Part2 Billet 3.7L single turbo - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 09-18-2016, 10:27 AM   #1 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Blue3kGTSL is an unknown quantity at this point
Feedback Score: 18 reviews
Default Full-car build Part2 Billet 3.7L single turbo
Since the old thread is pretty old now and all jumbled up from swapping directions on the build a few times - I decided to make a fresh new thread.
Here is everything in my possession, on the way to me, or assembled-
Engine:
JDM 6G74
Merkel 4340 billet 6g75 3.7L stroker crank
Custom Ross racing pistons
Billet Oliver/Pampena custom rods
Pampena HD wrist pins
ARP CA625+ main studs
A1 head studs
Ninja Performance big bore lifters
IPS 5-axis CNC ported "Race" heads with +2mm oversized valves
Merkel head lift fix
Brian Crowler springs and titanium retainers
Dynamic Racing 274 cams
BC/Pampena adjustable cam gears
OEM gasket set
OEM water pump
OEM oil pump with Italo Graso billet gears
OEM timing belt
Ninja Performance solid timing tensioner kit
Setrab/Maximal Performance oil cooler
Krank vents
Solid engine mounts
3SX Single Pass Radiator with Slim passenger fan
GReddy High Pressure Radiator cap
Mugen S2000/NSX thermostat
Pampena spark plug cover
HKS oil cap
New 1G Cam Crank angle sensor
OEM Knock sensor
OEM Coolant Temp sensor
Gene Performance singe turbo manifold and downpipe (Titanium wrapped)
Custom 4" downpipe
Precision 7675 DBB 1.15 a/r turbo (titanium blanket)
Tial MVR 44mm
Sound Performance quick spool valve
Custom ETS 5" 3/S fitment FMIC
Custom 3.5" intercooler piping
Custom FMIC ducting
TiAL BOV
IPS/HKS carbon ti 4" titanium exhaust
Fuel:
Pampena fuel rails
Custom RSI ID2000cc injectors
Fuelab FPR
Fuelab filter
3SX custom sending unit
Fuelab Prodigy 42402
Skillard fuel line cover
Ignition/Electronics:
ProEFI
HKS Type 0 Turbo Timer
Old school black face GReddy 60mm gauges -
-3 bar boost PWH
-oil pressure PWH
-temp (water) PWH
-oil temp PWH
-52mm fuel pressure
AEM analog wideband gauge
HKS twin power DLI
Magnecor R-100 Racing 10mm Plug Wires
Drivetrain:
US spec 6 speed
OS Giken R3C Triple Clutch
Rebuilt transmission using new bearings and seals
Bellhousing brace
Quaife Front LSD
Supercar Engineering Torsen center differential
Supercar Engineering billet shift forks
Broomfield Racing billet endcase
Torque solutions shift cable bushings
Torque solutions shifter base bushings
Blackline Weighted ARC Titanium Shift Knob Replica
Ohiospyderman's short throw shifter
STM master to slave SS clutch line
Reman slave cylinder
Pampena solid rear differential bushings
PST HD Race 1 piece carbon fiber driveshaft
Oem front hub assemblies
Brakes and suspension:
OEM ABS delete
Rebuilt calipers
Braided SS Brake lines
Hawk HPS brake pads
Carbotech slotted rotors
KSport coilovers
3SX rear adjustable upper control arms
Work Emotion CR 2 piece wheels
-189.5
-18x10
Exterior:
99 Front bumper
99 Turn signals
99 Sail panels
99 Rear garnish
APR GTC 500 3S specific wing
JDM tail lights
Interior/Miscellaneous:
Personal Neo Grinta steering wheel
Corbeau 5-point harnesses
Corbeau FX1 Pro seats on Corbeau sliders
Porno red carpet
Dynomat from rear seat bottom to rear of car
Battery relocate to rear
Trunk plastics/carpet/fiberboard removed
Active Aero delete
Cruise control delete
Rear wiper delete
Clutch booster delete
Power antenna swapped for flexible shorter rubber one
Vacuum reduction
Odyssey pc925
In the process of assembling the engine right now.
Have to finish modifying the oil pan, and have to modify the crossover pipe for the turbo manifold, and order what ever other small misc things that always pop up when you're just about to crank the car...
Master Elite KIA Technician
Past> Level 3 Chrysler & Bronze level Hyundai
1994 3000GT VR4 - 2012 Lexus IS250 F Sport - 08 BMW 335I
1988 Toyota Supra Turbo - Hers
Full-Car build Part 2!!!! Single Turbo Billet 3.7L stroker!!! CLICK HERE
Blue3kGTSL is offline   Reply With Quote Quick reply to this message
Old 09-18-2016, 10:28 AM   #2 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Default Re: Full-car build Part2 Billet 3.7L single turbo
Cleaning up, getting ready for head studs and head gaskets
Studs installed
Gaskets
Heads installed and torqued down
Turbo manifold mock up
Random picture of my turbo, nitrous bottle, and home decor lol
Old 09-18-2016, 11:15 AM   #3 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Devilmightcry Level 1Devilmightcry Level 1
Feedback Score: 19 reviews
Nice list of parts.
Devilmightcry is offline   Reply With Quote Quick reply to this message
Old 09-18-2016, 11:42 AM   #4 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Going to decide if i rather the combat wing or the GTC500 wing on here when it comes in.
Old 09-18-2016, 11:44 AM   #5 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
Originally Posted by Devilmightcry View Post
Nice list of parts.
Thanks.
Between the slowness of photobucket and this forum kicking me off for timing out, it took forever to get photos on here.
Old 09-18-2016, 01:30 PM   #6 (permalink)
pimprn's Avatar
Drives: GTO
pimprn Negative 1
Feedback Score: 8 reviews
That thermostat, can you explain why you didn't use stock , and such? Thanks man
Just because someone goes fast doesn't mean you should do whatever you think they did.This path assumes they knew what they were doing, which isn't necessarily the case. Take this path and you will be guaranteed second place.
pimprn is offline   Reply With Quote Quick reply to this message
Old 09-18-2016, 02:04 PM   #7 (permalink)
Drives: 93' VR4
It's cooler than stock.
Old 09-18-2016, 02:35 PM   #8 (permalink)
1PNCHMN
Blue3kGTSL's Avatar
Drives: 1994 VR-4
This.
I researched it and installed it long ago, so i do not remember the degree. I do know it worked out perfect in the middle of the Louisiana summer with ducting, ac, and a vent cut in the hood. I'm debating on getting a fresh one for this new build since that one has just been sitting.
Old 09-18-2016, 03:35 PM   #9 (permalink)
Drives: 93' VR4
Use waterless coolant. They don't pressurize the system to work and they don't cause rust.
Old 09-18-2016, 05:00 PM   #10 (permalink)
Resident Street Racer
NOMIEZVR-4's Avatar
NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1NOMIEZVR-4 Level 1
Feedback Score: 13 reviews
How much power are you trying to make? e85 im assuming because of the huge injectors?
96 Cianci Widebody 3000GT VR-4
R.I.P. Totalled January 2016
1995 Widebody 3000GT VR-4
NOMIEZVR-4 is online now   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
« nose mask | 4G Swap »
