Old 09-07-2008, 07:09 PM   #1 (permalink)
LI94VR4's Avatar
Drives: 94vr4
LI94VR4 Level 1LI94VR4 Level 1
Default front hidaway license plate?
After getting stopped here on long island a couple of times for no front plate, i figured i better put it on before i get a ticket. well this week i should be finishing up my 99 conversion and will not be reinstalling the front plate. i was going to try two options and was wondering if anyone has tried them yet?
1ST option is to use the sport/tour exhaust motor, relocate it up front, extend the wires from the plug in the rear to motor in the front and use the stock exhaust switch to raise and lower plate. (i have a couple of ideas for brackets and stuff to mount the plate to work with the motor.)
option 2 is to mount the motor up front like option 1 but wire it into the front active areo wiring. this would allow the plate to lower and raise along with the rear wing. I've tried wiring it this way already and got the motor to work but threw codes every try and had to reset them. the front wiring for the active areo and the exhaust motor seem to be similar but something is off. does anyone know where i can find the wiring schematics for both?
con's
option 1 : i might forget to lower the plate after being pulled over and get a ticket for no front plate, or worse for having a retractable plate.
have to run new wires from rear to front
option 2 : i don't usually drive around with the active areo turned on, so plate would normally stay down.
wiring might not be possible.
pro's
option 1 : can leave the front plate all the time until i get pulled over
option 2 : plate will lower on it's own every time i stop. and retract on its own at highway speed.
right now I'm leaning more to option 1.
if anyone has tried this before I'd like to know how you did it?
what do you think?
thanks for any info, Chris
LI94VR4 is offline   Reply With Quote
Old 09-07-2008, 07:23 PM   #2 (permalink)
I could kill you with....
HardCorps325's Avatar
Drives: 1997 3000GT VR4 Red
HardCorps325 Level 7HardCorps325 Level 7HardCorps325 Level 7HardCorps325 Level 7HardCorps325 Level 7HardCorps325 Level 7HardCorps325 Level 7
Default Re: front hidaway license plate?
why not have a linear actuator moving the plate from behind a fog light?
I haven't seen your car, but if you have a FMIC then you probably now have room behind your foglights.
1997 3000GT VR4 Suhmkinduh Red
HardCorps325 is offline   Reply With Quote
Old 09-07-2008, 07:28 PM   #3 (permalink)
ONALL4
byebye_sti's Avatar
Drives: 92 VR4
byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7byebye_sti Level 7
They make a fold away license plate bracket that attached to the bottom of your front bumper then folds underneath when you don't want it there.
My friend showed it to me the other day, but I can seem to find the link.
They make a manual one and an electronic one.
I'll try to find it.
EDIT:
FOUND IT!!
Altec Show-n-Go Retractable Front License Plate Holder - 400U
There is the link.
byebye_sti is offline   Reply With Quote
Old 09-07-2008, 09:11 PM   #4 (permalink)
CPTGTO's Avatar
Drives: 1999 VR-4
CPTGTO Level 1CPTGTO Level 1
That kicks ass! Haha it's even a NY plate, so I guess he got tired of getting pulled over too!
CPTGTO is offline   Reply With Quote
Old 09-07-2008, 09:18 PM   #5 (permalink)
99 SLut
Adollarwodbnice's Avatar
Drives: 99 SL
Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7Adollarwodbnice Level 7
I knew a guy with an NSX near me that has an electric one with a switch he can make it slide out and then slide back in... I think the kit was like 100 bucks though.
Adollarwodbnice is online now   Reply With Quote
Old 09-07-2008, 09:21 PM   #6 (permalink)
Computer Wiz
doggie504's Avatar
Drives: 93 SL,90 XJ6 75k mi.
doggie504 is an unknown quantity at this point
might be worth it lol
found this one
Retractable License Plate Motor W/ Control - Faceplates, Parts & Accessories, Automotive - nuLime.com
i would take the electric over manual any day
doggie504 is offline   Reply With Quote
Old 09-07-2008, 09:36 PM   #7 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7
Here in illinois its a secondary offense so they can only add it to your tab, not give you a tab specifically for it
Alt0id is online now   Reply With Quote
Old 09-21-2008, 05:11 PM   #8 (permalink)
LI94VR4's Avatar
Drives: 94vr4
Just an update. Messed around with bumper and plate today, just need to add the motor,spring and wire it up before paint.
Old 09-21-2008, 05:13 PM   #9 (permalink)
LI94VR4's Avatar
Drives: 94vr4
One more pic.
Old 09-21-2008, 05:24 PM   #10 (permalink)
Mr. Chocolate...
AudibleSilence's Avatar
Drives: 1997 3000gt VR4
Trader Rating: (47)
AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7AudibleSilence Level 7
Attachment 72883
Attachment 72884
Attachment 72885
Brother, be careful, if any part of the plate is obstructed and the cop is feeling like a jerk they can give you a ticket for "Improperly Displayed Plate." I got one myself, but I just stated that I didn't have a proper bracket etc etc etc.
1997 Black Top Red Mitsubishi 3000GT VR4 - 93k miles and 100% stock
Cars Owned:
1992 Dodge Stealth RT (sold)
1992 Mitsubishi 3000GT VR4 #1 (parted)
1992 Mitsubishi 3000GT VR4 #2 (sold)
1993 Mitsubishi 3000GT VR4 (KIA)
1994 Mitsubishi 3000GT VR4 (sold)
1994 Mitsubishi 3000GT Base - awd/atx (sold)
AudibleSilence is online now   Reply With Quote
