Old 02-04-2007, 03:30 PM   #31 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
Default Re: First attempt to widebody the badass3000
wow..this is getting out of hand..
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 02-04-2007, 03:42 PM   #32 (permalink)
By the power of Grayskull
MaG18's Avatar
Drives: Gingerly
Trader Rating: (25)
MaG18 Negative 1
plz dont use duct tape! use painters tape, the blue or green stuff. @ least on your paint
ChrisEs1984 : theres alot of pushrod lovers
Galganaban : i love to push my rod into your mom
shawnisworking : lol
shawnisworking : 0wn3d
MaG18 is offline   Reply With Quote
Old 02-04-2007, 04:45 PM   #33 (permalink)
King of ***
hellfire's Avatar
Drives: VR4, S14.5, S13, R6
Trader Rating: (28)
hellfire is an unknown quantity at this point
Originally Posted by sportsb4life7
thanks, i thought maybe he was just going for looks, which is another point for widebody not just to allow for greater tire width.... couldnt he just sawzall the front then too?
Right, sorry I didn't mean to jump your balls there. Just a little irritated today.
But, even if he is just purely going for looks with the widebody, then he will have very sunken in wheels, which doesn't lookg good at all. So he will either get wider wheels, or use spacers. Doing either of those puts the tire under the original fender if he didn't cut them and would rub like mad.
Also, yes he could just cut the inner front fender as well. But I imagine its easier to just make a full mold of the front, then you have lighter, fiberglass front fenders. You can't do that with the rear, becuase the rear quarters don't just unbolt.
Tyler
hellfire is offline   Reply With Quote
Old 02-04-2007, 05:24 PM   #34 (permalink)
Ross
Drives: 1995 VR4
Trader Rating: (7)
rossfashow Level 2rossfashow Level 2rossfashow Level 2
that is sooo sick motivates me to learn how to mold and fiberglass.
I <3 Boost.
1995 VR4 MoneyPit Edition. DBB DR-1000
rossfashow is online now   Reply With Quote
Old 02-04-2007, 05:57 PM   #35 (permalink)
Drives: 91 3000gt
SilverJester Level 1SilverJester Level 1
wow I never thought of using foam like that. That's a good idea.....not that I really have anything I want to fiberglass just yet, lol. Good job, keep us updated.
Performance Mods:
Spec Stage 3+ Clutch x2
South Bend Clutch Stage 3 OFE
300M Output Shaft
Gutted pre-cats
Stillen Downpipe
Slotted Rotors
SS Brakelines
ACPT Carbon Fiber Driveshaft
Prosport Gauges
Aesthetic Mods:
18x9 Weds Sport TC005
99 Sail Panels
99 Rear Garnish
"TWIN TURBO" decals
Tinted Windows
SilverJester is offline   Reply With Quote
Old 02-04-2007, 08:32 PM   #36 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
best of luck.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
Old 02-04-2007, 08:58 PM   #37 (permalink)
TPW: Promoter
1veryfastvr4's Avatar
Drives: 97 vr4
Trader Rating: (60)
1veryfastvr4 Level 11veryfastvr4 Level 1
as mentioned painters tape ftw!....
tape a big cloth down on inside of fender that covers engine baye for easy clean up
also cover wheels with something......
this is kida ballsy so im not sure what else to say but be careful......id hate to see something get ruined if it didnt work out......
1veryfastvr4 is offline   Reply With Quote
Old 02-04-2007, 09:00 PM   #38 (permalink)
TPW: Promoter
Drives: 97 vr4
Trader Rating: (60)
also didnt see if it was mentioned but what ever tape u use on the foam should be covered with wax, so the fiberglass will seperate from it when u pull it away....
Old 02-04-2007, 09:36 PM   #39 (permalink)
fastfalcon94's Avatar
Drives: 94 Panama Pearl VR-4
Trader Rating: (58)
fastfalcon94 Level 2fastfalcon94 Level 2fastfalcon94 Level 2
wow that's crazy. I wanna see how this turns out. My uncle used expanding foam on a rusted old truck before. he filled in all the holes. Then he cut the foam somewhat flush and tiger-haired over it. Sanded it smooth and used some spray paint. It looked fine and passed inspection. Good luck w/ the fiberglass, looking forward to more pics
Back in black, Will be in the 10's next summer. Parting out a Pearl White 1st gen stealth.
fastfalcon94 is offline   Reply With Quote
Old 02-04-2007, 09:40 PM   #40 (permalink)
Gas Cyphoner
SUPERTOM's Avatar
Drives: 95 BASE SOHC Stealth
SUPERTOM is an unknown quantity at this point
damn looks good so far. I just used that stuff last week to spray inside the metal underneath the interior panels to get rid of little rattles
PERFORMANCE:RiPP Headers,Maximal Catback,MSD (6AL Box, Blaster Coil, Wires),3SX Pulley,DOHC TBw/plenum port & coolant bypass,K&N filter w/HomeDepot Performance pipe & Supermac coldair wall, Topline GroundWires, Ek2 Plenum Spacer
WEIGHT LOSS:Removed (AC,SRS,crash bars,rearseat,tar, GasTank Shield,extra wires). Race seats,Hawker 12lb.battery. Hollowed trunk/trunklid,replaced random unseen bolts w/zipties, solid motormounts,CF Evo hood, Took a big dump -->
SUSPENSION:Ground Control, New KYB's, Front/Rear Strut bars, Dohc rear Anti-sway bar, Irotors brake upgrade
SUPERTOM is offline   Reply With Quote
