#23 (permalink) |
Great work so far. Can't wait to see how it turns out. You're probably inspire several members (maybe me too) to go for the homemade widebody.
I wonder how will the bumper match up to it?? Won't there big this big sweeping curve then just straight bumper?
Permanently broke! But her soul will be reborn into another VR4 soon. 92 VR4- Rebuilt engine with forged crank, TD05 manifolds with MHI EVO 3 16g, 6 speed conversion done, Maximal Solid Mounts, front mount 3" w/custom intercooler and intake pipes, OFE Stage 3 Clutch (from Southbend Clutch), SS clutch line, SS brake lines, SS oil and coolant lines, borla exhaust, stillen downpipe, egr block-off plates, LC-1 Wideband, blitz dc2 turbo timer, hks ssbov, Maft Pro speed density, Blitz SBC i-D III boost controller w/ Power Meter, k&n filters & custom intake pipes, gutted cats, 18x9 blitz type 03 wheels wrapped in Nexen N3000 tires, intrax springs, adj. control arms, 97 frontend and side conversion, 99 center tail light piece (<--adds at least 20hp on the dyno
#25 (permalink) | |||
Wanted: Traction Problems
But the front I wanted to remove the stock fender for more tire clearance. |
#26 (permalink) |
Hates Gravel
What are you going to do with the back side of it? That expanding foam is tough but it makes me a little nervous, I would want it as rigid as possible.
![]() 92 3000GT VR4 Black Wheel Mafia - Member 002 Matt |
#27 (permalink) |
keep up the good work,
i found this link a LONG time ago when i owned a DSM. http://www.fibreglast.com/contentpag...enter-286.html for all your fiberglass and other composite needs ![]() thanks, jesus |
#28 (permalink) | |
times two
What you are making for your front fenders is the pattern. You will make the actual mold from this pattern. Don't forget to include the mounting points for the fender when you build your mold. If you can get tooling resin to make your mold out of, do so. It cures very hard and is very durable. You will be able to get multiple copies of the fenders before the mold starts to break down. Use plenty of mold release/wax when you lay up the actual fender...if you want actually be able to pull it from the mold.
#29 (permalink) | |
King of ***
Tyler
#30 (permalink) | |
