#11 (permalink) | |
Wanted: Traction Problems
#13 (permalink) |
just be very carfull with great suff i have used it a million times it has super glue in it formula. you may want to try the black can of great suff it exspands 2x over the red and blue can.
but the job you have done look great keep it up, you may want to make a template. from what you have done so you can copy that on the other side. i would just measures the profile at x points that way it will work on both sides of the car. again looks great |
#14 (permalink) |
I put paper masking tape down first, and it didnt seem to go thru it to the paint.
I used the black can the second time, but I think it comes out 2x as fast. So your saying to just measure the thicknesses at several different points and duplicate it for the other side? |
#15 (permalink) | |
#16 (permalink) |
the car whisperer
Follow the instructions on the resign bottle closely. Mixing the resign and the hardener is important. Too hot and you won't have time to work. Too cold and it won't harden. Practice on something else small first. You don't want to screw up your nice structure you just made. I'd say, go find a tissue box or something and try to fiberglass around that. Once you've learned how to mix and spread it and all the little tricks like preventing air pockets from forming, you should be all set to try the fender.
Just my .02 Also, could this process be used to make a sub box? hmmmmmmm
96 RT/TT
Currently missing an engine. major performance mods: DR650's, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things. Waiting to get put in---> DR1000s with .48AR and stage 2 blade |
#17 (permalink) | |
TT's suck
#20 (permalink) | |
H to the izzO
