Old 09-08-2007, 02:01 PM   #111 (permalink)
Damage Control
Dark-Hawk's Avatar
Drives: `92 240SX
Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7Dark-Hawk Level 7
Default Re: First attempt to widebody the badass3000
Originally Posted by sportsb4life7 View Post
Maybe you should chill the fuck out, Mr.
You bumped the thread a few months ago and there was no update because he was rebuilding his engine; stop being a douche and let SOME time go by.
SOLD
Walbro 255, 450CC injectors, S-AFC, 300M output shaft, SPEC II clutch, RPS flywheel, ATR single shot exhaust, ATR downpipe, saner sway bars, PRM 3 pt strut bar, Greddy Type-S BOV, stillen cross drilled rotors, stillen brake pads, koyo rad
Dark-Hawk is online now   Reply With Quote
Old 09-21-2007, 08:15 PM   #112 (permalink)
bane of unintelligence
inperfectdarkness's Avatar
Drives: dreaming of a TT ecu
Trader Rating: (13)
inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7inperfectdarkness Level 7
looks good, badass. 18x10's with a 26mm offset would probably do the trick. i hope all the fenders come out symmetrical
inperfectdarkness is offline   Reply With Quote
Old 12-01-2007, 10:54 PM   #113 (permalink)
3kluv4life is an unknown quantity at this point
Hey man. Nice job so far. Im really into fiberglassing and planning on the same thing. Ill probably start after it warms up a bit. Keep it up.
3kluv4life is offline   Reply With Quote
Old 02-19-2008, 08:09 AM   #114 (permalink)
First VR4's Avatar
First VR4 is an unknown quantity at this point
Can't wait to see the finished project!
First VR4 is offline   Reply With Quote
Old 02-19-2008, 08:50 AM   #115 (permalink)
impulse's Avatar
impulse is an unknown quantity at this point
Remind me to shit down your throat next time you bump a thread...
impulse is offline   Reply With Quote
Old 02-19-2008, 08:55 AM   #116 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (46)
LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7
NS it was 3 months later!
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 08-25-2008, 08:00 PM   #117 (permalink)
First VR4's Avatar
Any update??
Old 08-25-2008, 08:28 PM   #118 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Originally Posted by TheOmniscientRT View Post
they have been doing that for years over there, so give it a couple more and it will be here, lol, we are about 10 years behind japan on trends
and not suprisingly, they are all rehashed things that were done already in some shap or form in the US
wraith is offline   Reply With Quote
