Old 07-08-2008, 06:30 PM   #1 (permalink)
Drives: 92 stealth rt tt
vashtsdaytona is an unknown quantity at this point
Default a few questions on my 92 tt, roof paint, wheels, rear calipers, shifter, spline
sorry for a long tittle thought id just combine all thses
1 roof paint. are all black roofs single stage or has mine been painted?
2 about how much would a nice set of used white RT/TT wheels cost? with/without tires, dont matter. and anybody know how much shipping would be for 4 wheels like that? mine are pretty nicked up.
3 about how much are used 2nd gen 2piston calipers??
4 if i understand correctly in 93 the stock shifter was shortened. how much was it shortend by? and how much used? and i assume thats an easy swap?
5 i read the other day that sometime in the 92 model year they made the switch to 25 spine out put shaft. anybody know what mine has? its manufactured in nov. of 91.
thank you very much for any and all answers.
vashtsdaytona is offline   Reply With Quote
Old 07-08-2008, 06:38 PM   #2 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7
Default Re: a few questions on my 92 tt, roof paint, wheels, rear calipers, shifter, spline
1 roof paint. are all black roofs single stage or has mine been painted? Single stage isnt used anymore, so if its been repainted, its not single stage.
1. The paint was single stage in 92, they switched to a base/clear later.
2. Check the classifieds
3. Check the classifieds
4. Direct swap, check classifieds for used one. About an inch and a half shorter.
5. Only way to know for sure is to pull the transfer case off and count the number of splines. Nov 91 build date is possible it has one.
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 07-10-2008, 12:19 AM   #3 (permalink)
well thanks for helping me out. im searching classifieds as we speak.
um also about the transfer case, is there not like a part number difference that might be stamped on it??
ugh! i know there were a couple more questions i came up with today, now i cant remeber them.
Old 07-10-2008, 07:06 AM   #4 (permalink)
Paid Member
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7Alt0id Level 7
I thought that the 25-spline was introduced in 93 model cars (built late 92)
Correct me if I am wrong.
Alt0id is offline   Reply With Quote
Old 07-10-2008, 07:56 AM   #5 (permalink)
3/S enthusiast
andyvr4's Avatar
Drives: 91 VR-4, 99 Zx2
andyvr4 Level 4andyvr4 Level 4andyvr4 Level 4andyvr4 Level 4andyvr4 Level 4
Nope, there are several 92's that had the 25-spline shaft as well. Any TT 3s with a production date after 11/91 COULD have the 25-spline shaft, but the production date is not a guarantee as some produced after that still ended up with the 18-spline.
andyvr4 is online now   Reply With Quote
Old 07-10-2008, 01:50 PM   #6 (permalink)
well i guess the spline will be left in mystery for a while.
i thought of my other questions.
what is the stock tint %?
also for my daytona it is common to use a larger oil filter, same diameter thread yadada only longer. the theroy is bigger filter flows more oil. is there such a filter for the stealth, that is bigger than OEM and still fits properly?
