Old 06-25-2008, 07:46 AM   #1 (permalink)
3/ser extroardinair
3000gt0's Avatar
Drives: a tank
3000gt0 is an unknown quantity at this point
Default Evo oil cooler
I tryed to look for this in the forums but never came up anyway I was wondering what the efficiency, flow rate, and size was compared to our oil coolers from the evo 8's and 9's I was thinkning of buying a used one and cleaning it out and adding steel braided lines.. just a thought I might do because Im broke and want to up grade something on my baby lol anyway any feedback is appriciated thanks in advance
P.S: this worked pretty well on my dsm but i used a starion oil cooler
apexi AFC2/AVC-R, HKS power transistor, NGK wires/ plugs, tein s-tech springs, 3K HID fogs, DNP hardpipe kit, battery relocated to trunk,
K&N filter, 25 spline trans., fidanza flywheel, stillen downpipe, gto garnish, and warlboro 341 fuel pump
3000gt0 is offline   Reply With Quote
Old 06-25-2008, 11:05 AM   #2 (permalink)
Drives: 1991 3000gt 99 cov
tigger is an unknown quantity at this point
Default Re: Evo oil cooler
i wouldnt buy a used oil cooler unless it came off a friends car and ya absolutly know nobody blown a motor through it
why risk your motor
so save how much?
Td05 Twin EVO 16gs , Blitz NUR Spec cat back w/ testpipe, M's Fuzzy logic boost controller , E-manage ult, Pte 680s , Act max street Clutch
tigger is offline   Reply With Quote
Old 06-25-2008, 10:39 PM   #3 (permalink)
3/ser extroardinair
3000gt0's Avatar
Drives: a tank
well wouldn't i be able to know if it was bad if i flushed everything out of it or if anything could come out at all before i put it in? and the external is fine if the fins are ok right? i mean would there be more to look for when buying an oil cooler?
