Old 04-17-2008, 12:18 PM   #1 (permalink)
NOTADSM
Polygon's Avatar
Drives: '89 GTC & '91 R/T TT
Trader Rating: (11)
Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7Polygon Level 7
Default Engine Running Very Rough
I came out this morning to go to the doctors office. When I started the car it started right up but it began running rough. The idle will drop and rise sporadically. I think it's running rich as it stinks of what I would say is fuel while it's running. Also, it does not throw a CEL.
All that has changed recently was that I took off the BCS to pull the plug and broke it. I got another one and put it back on. That was yesterday and it ran fine after I put the new BCS in. I also cleaned the MAS this weekend.
So, I can only suspect a few things right now, but I'm not sure. Please tell me you guys know what's up.
Polygon is online now   Reply With Quote
Old 04-17-2008, 12:19 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: Engine Running Very Rough
Your MAS is not plugged in.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 04-17-2008, 12:24 PM   #3 (permalink)
NOTADSM
Polygon's Avatar
Trader Rating: (11)
Actually, after I cleaned the MAS I had forgot to plug it back in. After starting it yesterday to get the new BCS plug I knew right away so I popped the hood and plugged it back in and drove off. So, today I checked it again and it's still plugged in, and I even unplugged it a couple of time and plugged it back in.
Old 04-17-2008, 12:27 PM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Is all the mesh in it and in the correct place? My mesh popped out once and the same thing happened.
Old 04-17-2008, 12:28 PM   #5 (permalink)
Drives: Red 1991 VR-4 (#3)
ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4ZephTheChef Level 4
Could be a big vacuum leak.
"why its a tubloidial butt noid!" - Ray Pampena, 2006
ZephTheChef is online now   Reply With Quote
Old 04-17-2008, 12:39 PM   #6 (permalink)
NOTADSM
Polygon's Avatar
Trader Rating: (11)
Yep, it's in place but there is a dent that has been there since the day I've had the car.
Old 04-17-2008, 12:41 PM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
White socks FTL.
Can you pressure test?
Old 04-17-2008, 12:42 PM   #8 (permalink)
NOTADSM
Polygon's Avatar
Trader Rating: (11)
White socks FTL.
Hey, I like white socks.
Sadly, I have no pressure tester to speak off. I'll go up and check the intake hoses.
Old 04-17-2008, 12:45 PM   #9 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Let us know what you find. Is the BOV leaking / hooked up loose? All clamps tight?
Old 04-17-2008, 12:47 PM   #10 (permalink)
<>_<>
Blizzind's Avatar
Drives: with lifter tick
Blizzind is an unknown quantity at this point
I fouled out my spark plugs because of how rich I was running before. You could have done the same with your MAS being unplugged I suppose. I highly doubt it though if it wasn't unplugged for a long period of time. Does it tend to fix its self after running it for a little bit?
Blizzind is offline   Reply With Quote
