#1 (permalink) |
Help with engine codes
-------------------------------------------------------------------------------- Hello every one first off I would like to thank you for the help. OK I have a 91 RT/TT fully built engine heads no cams with evo 16g's I popped my logger in and found these engine codes. 13, 14, 21, 22, 25 If anybody knows what they are and can give me some insight on way I have these stored I would greatly appreciate it. ( I personally think my ecu is on the way out ) I'm also getting this weired stuttering hesitation / fuel cut feeling sometimes while driving. Check engine light will come on for a little bit, then it goes away problems go away. It can do this once to twice during a drive to 20 times a drive. Then other days nothing.????? Any help on this would be great. Thank you Mike |
#2 (permalink) |
Curmudgeon
The whole list is here:
Stealth 316 - Reading Diagnostic Codes - 1991-1993 3S models 13 Intake air temperature sensor 14 Throttle position sensor 21 Coolant temperature sensor 22 Crank angle sensor 25 Barometric pressure sensor 13 and 25 are built into the MAF sensor on the air cleaner, I've had them show up if you turn the key to ON (or try to start it) with the MAF unplugged. I would clear all the codes since you don't know how old they are or if they're related and see which ones come back, and when. |
#4 (permalink) |
Here for the tuna.
Duplicate thread please refer to Help with engine codes.
