Closed Thread
Old 07-23-2008, 05:27 PM   #1 (permalink)
Drives: 91 rt/tt, 93 Bmw 325
Trader Rating: (9)
sciandra@epix is an unknown quantity at this point
Default engine codes
Help with engine codes
Hello every one first off I would like to thank you for the help.
OK I have a 91 RT/TT fully built engine heads no cams with evo 16g's
I popped my logger in and found these engine codes.
13, 14, 21, 22, 25
If anybody knows what they are and can give me some insight on way I have these stored I would greatly appreciate it.
( I personally think my ecu is on the way out )
I'm also getting this weired stuttering hesitation / fuel cut feeling sometimes while driving. Check engine light will come on for a little bit, then it goes away problems go away. It can do this once to twice during a drive to 20 times a drive. Then other days nothing.????? Any help on this would be great.
Thank you
Mike
sciandra@epix is offline
Old 07-23-2008, 08:45 PM   #2 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '93 ES, '92 TT
Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7
Default Re: engine codes
The whole list is here:
Stealth 316 - Reading Diagnostic Codes - 1991-1993 3S models
13 Intake air temperature sensor
14 Throttle position sensor
21 Coolant temperature sensor
22 Crank angle sensor
25 Barometric pressure sensor
13 and 25 are built into the MAF sensor on the air cleaner, I've had them show up if you turn the key to ON (or try to start it) with the MAF unplugged.
I would clear all the codes since you don't know how old they are or if they're related and see which ones come back, and when.
Steve '93ES is offline
Old 07-24-2008, 04:08 AM   #3 (permalink)
Trader Rating: (9)
Ah thank you very much I could not find this on stealth316. you must be a better searcher than me.
yeah I will reset the comp. wioth the logger. I will post back up some time this week.
Thanks again.
Mike
Old 07-24-2008, 04:20 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Duplicate thread please refer to Help with engine codes.
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
lawdogg is offline
Closed Thread
