Old 08-19-2008, 12:20 PM   #1 (permalink)
hated is an unknown quantity at this point
Default Driving on a blown turbo
did a search, and trying to figure out how far I can drive w/out fucken up shit. It's either that, or pay for a long distance flat bed. Holla!
move in silence...
hated is offline   Reply With Quote
Old 08-19-2008, 01:15 PM   #2 (permalink)
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (26)
Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7
Default Re: Driving on a blown turbo
Depends, if the oiling situation is bad enough or the stress on the turbine/compressor shaft becomes to much it can grenade on you. Sending metal through you IC piping. Chances are it will stop in the IC, but if it were my car I would not take the chance. Get a Uhaul trailer or something and tow it back.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
Patryn is offline   Reply With Quote
Old 08-19-2008, 01:50 PM   #3 (permalink)
Is it possible to bypass the turbo for the drive? I need to get 71 miles. Thanks for the response.
Old 08-19-2008, 01:53 PM   #4 (permalink)
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (26)
No, even if you diconnected the wastegate arm the turbo will still be spooling. If you want to save a flatbed cost just find a trailer or try Uhaul for a trailer and tow the car back. Should be about $40 to rent a trailer.
Old 08-19-2008, 01:56 PM   #5 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
Trader Rating: (46)
LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7LeRoyDL Level 7
how bad it it blown? You could bypass, but you are going to kill the turbo to the point of non rebuildable. (the center core anyway). Is it already scrapping the compressor housing? Depends on how bad of shape it is in already. If just leaking oil you could most likely make it okay if taking it easy, but again it all depends on how bad it is currently. Like mentioned above you don't want it tossing peices of itself through your intake/into your motor.
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
Old 08-20-2008, 06:12 PM   #6 (permalink)
Damn, thanks guys, looks like I can't be a cheap ass on this one. I'll go ahead, and grab a trailer. Thanks again.
