Old 06-18-2008, 09:29 AM   #11 (permalink)
Drives: 94 VR4
Trader Rating: (20)
Blue94VR4 is an unknown quantity at this point
Default Re: Dragging SPEC II, not sure why
Originally Posted by Gramdollar View Post
just to make sure. are you sure you adjusted the clutch pedal correctly? like didn't do it the opposite way
I would not be able to shift at all then It's all the way out.
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used A/C belt (10K on the belt)
2. Stock front and rear sway bars.
3. 3SX dual O2 simulator
4. Used 2'' couplers/reducers/hump hoses
5. SPEC II+ clutch
Blue94VR4 is offline   Reply With Quote
Old 07-06-2008, 07:44 PM   #12 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
hmm... i just expierienced the exact same problem with my stage 4 southbend.. cant figure it out.. must be internal.. maybe TOB?
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
