Door open - sensor? malfunction? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-13-2010, 07:33 PM   #1 (permalink)
norema's Avatar
Drives: 92' 3s SL
norema is an unknown quantity at this point
Feedback Score: 8 reviews
Default Door open - sensor? malfunction?
Hi,
Sometimes my car wont detect when my doors are opened; Its completely random, the dome lights will come on but the step lights do not. The open door symbol in the dash doesn't light up either. What electrical part is the culprit here?
I really wanna get this fixed,
Thanks
norema is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 11:22 AM   #2 (permalink)
soccermania688's Avatar
Drives: Mitsubishis
soccermania688 is an unknown quantity at this point
Feedback Score: 9 reviews
Default Re: Door open - sensor? malfunction?
Its the door trigger switch. Located in the door jamb towards the rear of the car. Its sometimes under a rubber boot so its harder to see. You can clean the contacts sometimes instead of replacing it.
NEW - BMW E92 335i 6MT BLK/BLK
OLD - 1995 3000GT VR4 - 6MT l SOLD l
1992 3000GT VR4 - 5MT - SOLD
1993 3000GT SL 5MT - SOLD
soccermania688 is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 12:16 PM   #3 (permalink)
all weather warrior
Drives: '85 900 Turbo
northener is an unknown quantity at this point
Feedback Score: 3 reviews
And squirt a little WD40 type oil in it. Sometimes they just stick in the "closed" position.
northener is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 12:41 PM   #4 (permalink)
Drives: '94 3000GT SL
textbookninja is an unknown quantity at this point
Feedback Score: 0 reviews
Had a similar problem, had to bend one of the contacts just a little bit. Be careful if you do, it seemed a little brittle. Touched some fine sandpaper to the contacts to clean them up and haven't had a problem since.
94SL, test pipe, 3SX crank pulley. 180K and still ticking.
They'll let anyone be a surgeon these days.
textbookninja is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 01:37 PM   #5 (permalink)
norema's Avatar
Drives: 92' 3s SL
I don't understand what a door jamb is -so the switch isn't in the door itself?
Is it by the rear speakers? inside that interior panel?
thanks
Old 12-06-2011, 06:33 PM   #6 (permalink)
Drives: 97 3000gt Base
path2insanity is an unknown quantity at this point
no its on the frame under the information placard. Its like the last part of the car that the door hits when it closes. Its a rubber button.
path2insanity is offline   Reply With Quote Quick reply to this message
Old 12-06-2011, 06:59 PM   #7 (permalink)
Flasher
TwIzTeD_3kGt's Avatar
Drives: VR4 | VR4 | R/T
TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2TwIzTeD_3kGt Level 2
Feedback Score: 24 reviews
Below the latch just above the side skirt. Either replace it or try to clean the contacts on it.
'97 VR4 - 19t, Chrome, E85, DD, Since '06
'06 Envoy SLT - Black, clean, DD
'98 Expedition EB- Work/Winter horse
'93 VR4 & '94 R/T - Projects
TwIzTeD_3kGt is offline   Reply With Quote Quick reply to this message
Old 12-06-2011, 08:58 PM   #8 (permalink)
mas
mas's Avatar
Drives: 95 R/T TT
mas is an unknown quantity at this point
Feedback Score: 5 reviews
just fixed this 2 weeks ago on my 95 stealth.
Open the drivers door. near the rear of the car on the BODY section you cant see with the door closed. where the striker is that the door closes on. there is a rubber boot looking thing. near where you would see the tire stickers and body vin number stickers.
It is screwed in on mmine. phillips head. rubber boot. about 1 inch by 1 inch.
Unscrew it and pull it out some.
Fish the wire out some and unclip the plastic/rubber door thing from the connector.
DO NOT LET THE CONNECTOR AND WIRE FALL BACK INTO THE HOLE/DOOR JAM. just wrap some tape or bend it sharply or zip tie so it wont fall back in.
the rubber boot/ cover just slides over so just unslide it off the metal switch.
the switch has 2 little clips holding it together. this is on the plastic sides near where the connecor connects. pry them apart.
The whole thing comes apart at this point and there are springs so go easy and do this where parts can fly or fall and NOT GET LOST.
on all the metal contact surfaces spray some carb cleaner on them. then take a pencil with an eraser and rub on the metal contact points. or FINE sand papaer..
spray a small mist of WB40 in the connectors and plop the spring back in and reclip the switch back together. take it back over to the car and slide the original rubber boot back over it.
Reconnect the clip/harness. and bolt it back down to try the rebuilt switch out.
Now do the other side.
Seems as if moisture gets in the switch and corrods the copper connections like the inside of an off VCR remote. Cleaning the contacts fixes the open circut and allows your lights to work just like new.
Have a good day.
* edit: and all this great tech from a guy with bad karma.. boo.
1995 RT TT Galaxy white Pearl. 1 intercooler delete. 1 exhaust delete. More fuel
If SHTF, I want to be out of the room before then.
mas is offline   Reply With Quote Quick reply to this message
Old 12-07-2011, 07:31 AM   #9 (permalink)
3Si Co-Founder
SUTHNR's Avatar
Drives: Everywhere
SUTHNR is an unknown quantity at this point
Feedback Score: 16 reviews
Switch In Door Jam for Lights*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
Listing also includes a link to a brief writeup on swapping it out.
EricB
Eric "SUTHNR" Bowden's Garage
* 1993 Dodge Stealth R/T - NG09 & NG14 Best All-Round 3S TWICE - NA POWA!!
The 222 HP Stereo... The MOST modified slowest naturally aspirated FWD Stealth out there.
* 2008 Toyota Tundra Pick'm'up Truck
Mods: Right Foot FTW!
* 2010 Toyota Corolla
Mods: The Wife FTW!
* My stereo site lives here: The 222 HP Stereo...
* My personal venture:
Edgy Elegance Photography - Weddings, Home Sales, Automotive, etc!
* I love taking and creating Panorama Pictures: Check out my Panorama Gallery
* The 3000GT/Stealth Collectibles Site: Ultimate 3S Collectibles Archive
* Visit 3SX for record setting parts at www.3SX.com
NG10 Pics LOADED!
3SX 1/4 Mile Times
3SX T2 FWD 3S 10.19 @ 140.31
3SX T4 AWD 3S 9.214 @ 154.98
Also T4 AWD 3S 9.339 @ 159.23
3SX twitter | 3SX FaceBook
SUTHNR is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
