#51 (permalink) |
One too many projects...
Hey guys, got the caps today, I'm going to try to get them in tomorrow, will let you guys know what happens.
'92 Pearl White R/T
Driver, pretty much stock. ![]() 1967 Dodge D200 5.7 HEMI 1971 Dodge Challenger 383/727 ![]() |
#52 (permalink) |
the car whisperer
Be careful. That film on the board burns easy.
96 RT/TT
Currently missing an engine. major performance mods: DR650's, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things. Waiting to get put in---> DR1000s with .48AR and stage 2 blade |
#54 (permalink) |
Timeout- Got the comp out, doesnt look anything like this.
![]() Mine has 4 plug ins on the back. One big red one, and 3 smaller ones in red, yellow, and blue. WTH, has mine been replaced? There are no medium sized caps. There are only a few really large ones, and a bunch of 50v 10uF ones. I'm kinda pissed now, anybody know whats up? |
#58 (permalink) |
Agreed - did you pull this out from behind the center console under the dash? There are some pretty good write ups on 316 or Wikepedia on how to get it out.
91 AWD TT
K&N, Exhaust upgrade, Blitz DSBC, Steel braided brake lines, Aluminum pulley, Vacuum reduction, Egr block off, Tirerack Wheels ![]() Scanmaster 3 installed - now I need to figure out what it all means , Palm M515 LoggerTo do list: Gut the cats - fix the friggin antenna that won't retract ![]() Revel in your time |
#59 (permalink) | |
I looked on the wiki, the "how to get the ecu out" link didnt work for me, like 5 or 6 times I've tried, it tells me that I need to login to edit, there isnt anything there. ![]() Last edited by WhiteR/T : 10-31-2007 at 06:58 PM. |
