Old 07-07-2008, 08:29 AM   #131 (permalink)
Dru
Drives: 91 Stealth R/t Stock
91rtstealth is an unknown quantity at this point
Default Re: do these cars ever idle correctly?
Originally Posted by 92rtawd View Post
I have the EXACT same problem. Hesitation until it warms up and then hesitation under very light throttle. I've pressure tested a lot. I believe its something other than vac leaks.
every time I have a weird and unique problem with my car, I assume i'm the only one the earth with that problem...it's always surprising to see someone else has the exact same problem, but it's also comforting..haha..
have you done anything with the throttle body? I think it's something to do with the TB because the TB would have a lot to do with allowing the car to warm up (adjusting air/vuel....choking basically)....if it's not doing that right, it would explain why the car runs like crap at first....
what have you tried thus far to check it? i always thought it was because my IAC was bad, but i replaced that and it still does it...it's just really annoying when i'm cruising through traffic...if you hold on your throttle around 2-3 grand, does it pop and miss? try it...just put it in neutral and barely lay on the gas...mine misses, and this is what causes the car to wiggle and jerk about...but if I nail the throttle, all is well..i don't get it...
91rtstealth is offline   Reply With Quote
Old 07-07-2008, 12:34 PM   #132 (permalink)
Rock Chalk, Jayhawk
92rtawd's Avatar
Drives: 92 Stealth TT
Trader Rating: (6)
92rtawd is an unknown quantity at this point
I'll give that a try in neutral.
So far, I've replaced plugs and coil packs, injectors, and I've pressure tested.
The other thing I can see making a difference warm or cold is that the car goes to open loop mode when it warms up. Maybe you're onto something with the throttle body.
I just can't think of much that would cause a miss at low load and be fine at higher loads.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
92rtawd is offline   Reply With Quote
Old 07-07-2008, 12:38 PM   #133 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Hate to say this, but your problem sounds eerily familar: Lean Misfires at 2700-2800 rpm
Old 07-07-2008, 05:06 PM   #134 (permalink)
Dru
what is open loop mode?
and yeah...i don't get it either..hah...
however, once I get home from work, i'm going to read that long thread that was just posted...that sounds interesting...
Old 07-07-2008, 06:15 PM   #135 (permalink)
Also known as MacGyver
marshallh's Avatar
Drives: 1994 3000GT Base
marshallh Level 1marshallh Level 1
94 N/A
My car does this exact thing: runs fine, except hesitates and jerks under low acceleration.
Here's what happens:
I go about 30mph, shift into 4th, and try to accelerate. Just cruising is not a problem, but once I put some gas into it, it starts hesitating. Also does it when starting in 1st from a stop. No problems at WOT.
I checked my ISC today. One of the coils is bad so I loosened the BISS a bit to keep an idle around 1000RPM. ECU looks OK (It's a 94) but I'm replacing the capacitors anyway.
For anyone needing a new ISC/IAC: Get one for $72 here new:
RockAuto Parts Catalog Part Number AC99
Originally Posted by Ketchup
this gave me fuzzy feelings inside
marshallh is offline   Reply With Quote
Old 07-07-2008, 07:08 PM   #136 (permalink)
Dru
i read through this a little bit..it doesn't sound like the exact same problem I am having...
i've recently replaced my ISC and ECU caps....still misses. I even tried unplugging the ECS computer to see if it was messing with my main ECM...didn't change anything....
Old 07-07-2008, 08:44 PM   #137 (permalink)
Dru
i just went outside to see if my misfiring problem was in between any certain idle speed, and it's not....it's only when i'm light on the throttle...however, I did notice that it does miss a little during high idle...it's kind of chilly out..so the high idle was approaching 2k when I started it...it was missing a little then too...it's just a little gurgling/bubbling sound coming from the exhaust at idle, but still noticeable...but yeah, i tried 1500, 2500, 3500...it misses....
