Old 03-19-2008, 01:30 PM   #121 (permalink)
Dru
Drives: 91 Stealth R/t Stock
91rtstealth is an unknown quantity at this point
Default Re: do these cars ever idle correctly?
congrats man...i atually had my 60k tune up done this past summer..and it still chugs...so who knows..these cars are nuts..but u gotta love em..haha...oh well..i'll deal with the chugging..idle seems pretty good now that I got the ECU repaired...well, the caps replaced...
91rtstealth is offline   Reply With Quote
Old 07-06-2008, 08:00 PM   #122 (permalink)
Dru
well....the day has finally come...my car idle's perfectly...i'm ecstatic...i just drove it to the shore this weekend and it didn't stall once..haha..all it was was the ISC...I actually bought a used one a few months ago and it didn't fix it..turns out that used one I bought was bad TOO!!..so I got one that came from a car that ran right, installed it, and i'm good to go....thanks to Hans at Ground Zero Performance for that...
so...here's the status of my car...everything is fixed but ONE tiny thing that annoys me...if I lay on the throttle very lightly, the car misses...you can hear all kinds of pops and rumbles from the exhaust...as a result of this, when i'm barely on the throttle (driving in slow traffic, cruising on the freeway) the car jerks back and forth.....it's insanely annoying when I'm cruising on a street really slow or crawling in traffic..cuz the car jerks back and forth...however, if I floor car, it runs perfectly...
another thing I noticed, and this may be related....if I get in the car and drive it immediately it hesitates until it warms up....even when it's 80 degrees outside, I have the let the car warm up otherwise it hesitates until it warms up all the way...it's like the car is getting too much air or fuel....
anyone have any suggestions? a few people said vacuum leak, but wouldn't it hesitate during wide open throttle then?
someone else to clean the MAF....what else would you suggest? it sound liek it would be something with the throttle body...
Old 07-06-2008, 08:03 PM   #123 (permalink)
CUSW Co_Prez
Drives: in reverse
blindmist is an unknown quantity at this point
anyone know where to get the o-ring for the BISS?
blindmist is online now   Reply With Quote
Old 07-06-2008, 08:06 PM   #124 (permalink)
CUSW Co_Prez
Drives: in reverse
The motor doesn't produce vacuum under full throttle.
Old 07-06-2008, 08:17 PM   #125 (permalink)
Dru
hmmm....so it IS possible that I have a vacuum leak....it's the strangest thing...it's only under really light acceleration...when you're barely on the throttle...it's so freaking annoying when you're trying to cruise through traffic in second 10-15 miles per hr or so....i'm anal..hah...i want the car to run perfectly...
i thought it might be the o-ring in the biss screw as well..I think it's something ot do with the throttle body, because the car hesitates a lot when the engine is first started....once it warms up, it's fine...
Old 07-06-2008, 09:15 PM   #126 (permalink)
CUSW Co_Prez
Drives: in reverse
good chance. also, you might want to check your motor mounts if it is jerking the car really bad.
Old 07-06-2008, 09:23 PM   #127 (permalink)
Dru
it's def not hte motor mounts...it's a very minor jerk..but enough to annoy me...
Old 07-06-2008, 09:27 PM   #128 (permalink)
CUSW Co_Prez
Drives: in reverse
well, i would suggest doing a vac. reduction and seeing if it does the same thing.
I am assuming this is on a NA stealth. Very simple to do and will shortly determine if it is a vacuum leak or not
Old 07-06-2008, 10:29 PM   #129 (permalink)
Dru
yeah..it's NA..how do I do this vac reduction test?
Old 07-06-2008, 10:34 PM   #130 (permalink)
Rock Chalk, Jayhawk
PhillipTT's Avatar
Drives: 92 Stealth TT
Trader Rating: (7)
PhillipTT Level 4PhillipTT Level 4PhillipTT Level 4PhillipTT Level 4PhillipTT Level 4
I have the EXACT same problem. Hesitation until it warms up and then hesitation under very light throttle. I've pressure tested a lot. I believe its something other than vac leaks.
AIR: WRX 13T turbos, Greddy FMIC, K&N Filter, A'pexi twin chamber BOV, Greddy Profec B, ESP downpipe, IPS single shot catback
FUEL: Greddy E-Manage,Walbro 255lph pump, IPO hotwire kit, AEM AFPR, 450cc injectors
SPARK: MSD wires, NGK plugs
DRIVETRAIN: PST 2-piece CFDS, Centerforce dual friction clutch
PhillipTT is offline   Reply With Quote
