Old 02-19-2008, 10:19 PM   #111 (permalink)
XxStealthxX's Avatar
Drives: Dodge Stealth R/T
XxStealthxX is an unknown quantity at this point
Default Re: do these cars ever idle correctly?
I had this problem with my car too, all you need to get is a new idle air control valve, takes 10 min to install but its about 400 to 450 bucks...
XxStealthxX is offline   Reply With Quote
Old 02-20-2008, 08:08 AM   #112 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (29)
Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5
You can get new ones on ebay for like 120-150 bucks.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
Highboosted is offline   Reply With Quote
Old 02-20-2008, 11:55 AM   #113 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
I'm not reading this whole thread, but my car idles like a dream.
The fix? A brand new throttle body straight from the dealer. It's $550.00, but is complete and comes with a new IAC, TPS, FIAV, Dashpot, the works.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 02-21-2008, 10:48 AM   #114 (permalink)
Dru
Drives: 91 Stealth R/t Stock
91rtstealth is an unknown quantity at this point
good point...it is the easiest fix....costs a lot, but putting a new throttle body on is easy as hell..
91rtstealth is offline   Reply With Quote
Old 02-21-2008, 06:09 PM   #115 (permalink)
Hammer
Drives: 95 3000gt vr4 stock
Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7
Or :
Replace your vehicle's dead/dying ISC with a
GENUINE MITSUBISHI
BRAND NEW ISC
$131.75 each
at http://www.dsmisc.com/dsmweb-dw/index.html
Hammer is offline   Reply With Quote
Old 03-10-2008, 04:26 PM   #116 (permalink)
One too many projects...
WhiteR/T's Avatar
Drives: Stock 92 Stealth R/T
WhiteR/T is an unknown quantity at this point
VICTORY!!!
Well, its been a long battle, but it is over. I have won. I just completed the 60k service, and it runs like a top. Idle is perfect, no chugging in gear. I found the problem:
When I took the timing belt off, I marked where the cam gears were compared to the head. Go to put it back together, and the rear head ones were fine. Turns out the front cams were off a couple of teeth. I'm pretty sure it didnt jump it, the belt was too tight when I took it off. The moron kid that had it before me probably just put on a belt, and messed up the timing. Thank goodness he didnt wreck anything.
So, if you are having idle/chugging problems, and have checked the easy things, CHECK YOUR TIMING!!!!
'92 Pearl White R/T
Driver, pretty much stock.
1967 Dodge D200 5.7 HEMI
1971 Dodge Challenger 383/727
WhiteR/T is offline   Reply With Quote
Old 03-10-2008, 05:56 PM   #117 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 63Sfever level 6
Great news!!! I bet that is one heck of a relief.
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
Old 03-10-2008, 07:45 PM   #118 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
I am with you. Its a waste of time trying to rejuvenate an old unit to make it run like new again. I had 117k miles and just got a new one which made the car run like new again.
Sam
wraith is offline   Reply With Quote
Old 03-10-2008, 11:40 PM   #119 (permalink)
Hammer
Originally Posted by WhiteR/T View Post
VICTORY!!!
You must have had problems with the engine beyond just idle speed then.
Your thread title is a bit misleading.
Old 03-11-2008, 07:41 AM   #120 (permalink)
WhiteR/T's Avatar
Yes, it was missing some.
It is not my thread.
