#81 (permalink) |
Supporting Vendor
My car has Ross Pistons, and even on it's 1031 hp hp Dyno pulls the highest knock count the stock ECU ever showed was a 4 count. On the track on my 8 second passes on 1 pass it showed a knock count of 1. That’s a prity dam quiet 1000hp motor if you ask me, ross pistons and all.
![]() 93 RT TT 8.81@166.7mph @3600ft Worlds Quickest and Fastest 3000gt/stealth 95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold) 92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold) 95 RT TT 10.88@129.1mph @3600ft (sold) 95 RT TT 11.9@118mph (stock injectors) 2004 F350 Harley 14.4@90mph at 3600ft 2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP 2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq There are 2 ways to make a car fast. #1 use the Right combo of parts #2 Throw so much money at it that the car has no choice but to be fast. I choose #1 Click for US 3S Fastest ET list Better to be a racer for a moment then a spectator for a lifetime "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge |
#82 (permalink) | |
Supporting Vendor
#83 (permalink) |
Very informative posts as usually Ray. Always learning something when you post, should do it more offen, you get lunch breaks at Toyota right?
Can someone explain to me why STOCK Ross pistons are noisy?
----------------[2007 Ride of the Year
![]() ![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() Last edited by oohnoo : 07-16-2008 at 07:11 PM. |
#85 (permalink) |
One Sinister Motha Sucka!
I bought ross pistons from ips. Are those different from what your talking about?
91 Vr4, TDO4L 13T's, heads ported and polished, oil cooler, new vss, new valves, springs, rebuilt engine with 99 big bore lifters, Fel-pro head Bolts, IPS Ross (.030) Pistons and Rings, brand new forged mitsu oem crank, clevite bearings, all new gaskets and seals, new oem oil pump, new water pump, all new gears and synchros(1-5 and reverse) new oem motor mounts, VIS Carbon Fiber Hood, R1 Performance Drilled Slotted rotors, JDM amber taillights, 99 Headlights, Tein S Springs, 99 rear Garnish, Greddy Profec-B Spec II EBC, evo8 560cc injectors, Apexi SAFC-II, walbro 255 FP, 120k, hks SSQV, borla 3", downpipe, gt-pro FMIC, XTD stage 3 racing clutch, Brand new two tone custom interior, x2 Kicker Comp 12" subs, infinity Kappa 3 stage 6x9's, 98 conversion!
#87 (permalink) |
Corn Its whats for boost
what skirt to wall do you use?
AEM Factory Trained Tuner
![]() 91VR4 Black-5027s-3.0L-Stock heads and Cams- 770AWHP 670AWTQ uncorrected 33psi E90 Daily Driver SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#88 (permalink) |
Supporting Vendor
although i hate telling other engine builders how to do things (not you Chris/3sx lol) .0045" gives long life and no noise. if theres noise, they are looser than that.
my custom piston uses a custom barrel/cam design that has a stronger skirt for even more life and abuse. all shelf stock pistons of any brand are designed for what they think you would need. a general application race piston in your bore and comp height. the ones i built are for THESE engines only and are built around a trick ring pack and custom barrel. Sin, you will be fine with those shelf units if you use the right piston to wall. a good machinist will know whats best for you. if they are set up too loose, just like with ANY piston, you will have noise. im on a goddamn post a thon! |
#89 (permalink) | |
