Old 07-14-2008, 08:01 PM   #71 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (26)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
Default Re: Do Not Tune With Safcii??
Originally Posted by ray pampena View Post
holy shit i missed this post!! low timing does NOT melt pistons hahaha it makes the egt read high because the flame front is out the exhaust making the sensor read high...meanwhile the cylinder temps themselves fall as does the power. did the 2 best tuners in the world forget to let you know that?
now as far as you being here to help, i havnt seen a helpful post yet... lets see, Sin coulnt get tuned because the tuner was worried about high timing due to the negative afc correction. so, i tell him to turn the cas back so it will cancel out the added timing of the afc.. GOLDEN INFORMATION WHICH IS FREE HERE ON 3SI.
you say how id get owned on a tuning forum lol and how theres this whole math to changing the timing.. TIMING LIGHT ANYONE?
what happened to the free advice? what happened to the free mods? why are the simple things always overlooked. thats my point Dennis
ps egt readings are for diesels. low egts and hight timing=melt down. high egt with low timing makes exhaust glow and power low with NO engine damage.
The shop that was he took the car was trying to upsale him on equipment. While you are giving him advice on cancelling out the timing correction of the afc and larger injectors, and while your method IS FREE, is not the best way to adjust timing. Its like saying arc2 is better than aem. While arc 2 is tried and true and gives results, aem is better because you have control over numbers very precisely. I never say your way didnt work. But you must admit there are better ways (while costing money) and more precise ways of doing it. I understand your methodoly of going about things. The least expensive way that works. there is nothing wrong with that.
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 07-14-2008, 08:07 PM   #72 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
+1 Rep Given
BAM...you now have another shiny green box (like you care LOL )
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 07-15-2008, 05:01 AM   #73 (permalink)
Supporting Vendor
ray pampena's Avatar
Trader Rating: (6)
ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7ray pampena Level 7
Originally Posted by Import Power View Post
+1 Rep Given
hahaa nice! i miss 3si sometimes lol
can't understand normal thinking
ray pampena is offline   Reply With Quote
Old 07-15-2008, 05:32 AM   #74 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Ray - back on topic - what if you can not adjust your base timing? Tuning with an SAFC on a 2g VR-4?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 07-15-2008, 06:45 AM   #75 (permalink)
Supporting Vendor
Trader Rating: (6)
i honestly never have a problem with that when you have reasonable sized injectors. heres why, the car has a conservative timing map to begin with. the you add some timing with your injector and fuel controller... which ends up helping power wise.
if you are having a problem and need to move it back, a timing control is then needed or you can slot the trigger plate holes using a degree wheel and move it back 3-5 degrees.
it all depends on what injectors you are running. the trick is, only run what you need to get the power you want and timing wont be a problem
Old 07-15-2008, 06:48 AM   #76 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Thanks!
If only there was a way to tell if knock is coming from timing advance or something else ...
Old 07-15-2008, 09:45 AM   #77 (permalink)
Supporting Vendor
Trader Rating: (6)
Thanks!
there is. if you suspect knock, add race gas and leave everything else alone. if it stays the same, its not real spark knock.
Old 07-15-2008, 10:27 AM   #78 (permalink)
Supporting Vendor
Trader Rating: (6)
also, while im on the information kick and i also cant stop laughing about the egt, timing , and melted pistons comment.. let me elaborate some on that
when you have X amount of fuel, X amount of air(boost or not) you have X amount of potential energy. if the timing is say 15 deg and boost is 20psi.. and we will give it an AF of 11.8:1. lets say the egt reads 850deg c.
now, make the timing 12 and leave all else alone, and you will see an increase of egts. this is because more of that given energy described above is wasted into the exhaust instead of being used in the combustion chamber.
now run 20 deg timing. you will see lower egts from the same reasons. now the energy is going into pushing down the piston and making more power. you will have a lower reading like this. the piston can only take so much of this heat which creates knock and can also melt a piston.
if you monitor boost, af, and knock.. there is no reason to look at egt. if you have X boost, X timing, X knock and all of those are good.. it doesnt matter if your egt gauge reads 2000 deg. if all items are the same day in and day out and one day you have a problem.. you will see it in af or overboosting before you would ever need to rely on egt readings.
to complicate this even more. the aspect ratio of exhaust pressure vs boost changes with all turbo designs, header designs, intercooling, pipe sizes etc etc etc.
if you have a 2:1 ratio, then you will have a MUCH higher reading than someone running 1.3:1. BOTH of those cars can have the same cylinder temp but WAAAY different egts do to the compression of already heated exhaust gas.
i hope this helps you out Dennis and Sin. this is more valuable info that people seem to not know.
i dont claim to know everything. i have barely have a 10th grade education, never went to AEM school or any tuning school. i learned on my own. i did not have the "best tuners in the world" teach me.. whatever that means.
everyone can learn something from someone..including me
Old 07-15-2008, 10:43 AM   #79 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Absolutely agreed. I determined a long time ago that my EGT gauge was worthless with regard to tuning. I'd never really put a lot of thought into why my EGT's went up with reduced timing, but it surely did. That was around the same time I stopped running bullshit timing levels...
If you know what you're doing, there's no need to bottom out people's timing maps to make safe power. I guess that works when you're not willing to put any real amount of time into their cars,,,,,,,,,,asdf,,, though.
Ray, for the record, we're covering heat of combustion in thermal fluid systems right now. What you said makes perfect sense.
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Congrats to the current top 10 members!!
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 07-16-2008, 02:27 PM   #80 (permalink)
Supporting Vendor
SnakeSkinner's Avatar
Trader Rating: (32)
SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7SnakeSkinner Level 7
100% correct allot of people have a hard time understanding that one.
93 RT TT 8.74@168.5mph @3600ft Worlds Quickest and Fastest 3000gt/stealth
95 3000GT VR-4 10.56@136mph- 714 AWHP & 607 AWTQ (dr-900's) (sold)
92 Stealth RT TT 10.69@133.45mph @3600ft (dr-800's) (sold)
95 RT TT 10.88@129.1mph @3600ft (sold)
95 RT TT 11.9@118mph (stock injectors)
2004 F350 Harley 14.4@90mph at 3600ft
2007 Charger SRT-8 12.3@120mph@3600ft, Heads/cam, NOS 548 RWHP
2001 Dodge Viper GTS Heads/cam 612 rwhp & 619 rwtq
There are 2 ways to make a car fast.
#1 use the Right combo of parts
#2 Throw so much money at it that the car has no choice but to be fast.
I choose #1
Click for US 3S Fastest ET list
Better to be a racer for a moment then a spectator for a lifetime
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelict."— John Calvin Coolidge
SnakeSkinner is offline   Reply With Quote
