Old 06-25-2008, 03:41 PM   #1 (permalink)
LP_Stealth's Avatar
Drives: 95 Stealth TT
LP_Stealth Level 1LP_Stealth Level 1
Default Disappearing Coolant!
OK well for the last week my coolant has been disappearing so I have been monitoring my temp and coolant level and I lost probably 2-3 liters within the week. I have been searching on here and it seems like my water pump might be leaking.
I looked under my car and it seems like it IS leaking coolant on the drivers side (I tasted it and it is sweet). My car has 69000 miles and I NEED to get the 60K done I have just been dirt poor.
What is the going rate for a 60K? and what are all the parts needed?
water pump.
timing belt.
plugs.
wires.
If I cant find someone around here to do it for me I guess I will just have to take it to the dealership
PS I am in Calgary AB.
Ken
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you make it through the wall.
LP_Stealth is offline   Reply With Quote
Old 06-25-2008, 03:51 PM   #2 (permalink)
Grandpa
EVILTWIN's Avatar
Drives: 07Accord, 03 C5 ann.
EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7EVILTWIN Level 7
Default Re: Disappearing Coolant!
Dealer's will probably charge you North of 2000 to do a 60K service.
Try really hard to find someone who can turn a wrench near you and save a boat load. It's well worth it.
Set the gearshift, for the high gear of your soul.
Chuck Norris can win a game of Connect Four in THREE MOVES
I'm an Equal Opportunity Annoyer!
EVILTWIN is offline   Reply With Quote
Old 06-25-2008, 03:57 PM   #3 (permalink)
Verified Eagle Scout
jacob666's Avatar
Drives: '91 "GT", '91 R/t
Trader Rating: (9)
jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7jacob666 Level 7
this is pretty much what you need for the 60k... all in one bundle
IPS Motorsports
looks like the going rate is $383.59+shipping lol
as far as someone to do it for you... not too many 3s'ers in Canada... you may need to go a different route, or if you want, try doing it yourself but thats up to you if you feel your competent or not, there's plenty of walk throughs around.
jacob666 is offline   Reply With Quote
Old 06-25-2008, 04:00 PM   #4 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '93 ES, '92 TT
Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7
water pump.
timing belt.
plugs.
wires.
Don't forget:
Tensioner
Idler Pulley
Tensioner Pulley
Anti-freeze & distilled water
If money's tight you can do it in two steps,
do the water pump/timing belt/tensioner/pulleys now and do the plugs/wires/filters etc later.
Steve '93ES is online now   Reply With Quote
Old 06-25-2008, 04:06 PM   #5 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7Colt45_GTO Level 7
if you aint bad with a wrench then attempt it your self. its not really hard to do. i think there maybe a tut on stealth316 i'm not sure. but you will need timing belt kit, water pump (genuine), oil/ oil filter etc etc.
the easiest way to do timing belts is to remove the radiator and altinator the rest flows. the tricky bit is the power steering belt tensioner pully just remove the two bolts that hold that on. and use a long 1/2" braker bar to crack the crank bolt. wedge it against the car in the direction of rotation and crank the engine but don't start the car.
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Originally Posted by Stealthee View Post
Seriously. Just like people will talk down to you when you post about getting a ticket.
People on here need to learn when to shut the fuck up and stop being hypocritical.
