#1 (permalink) |
Het guys,
My dash lights went out the other day after installing a new stereo in my 1995 3000gt. I checked every single fuse in the car and none were blown. Then my tail lights went, but that was a blown fuse. From what I have read about this problem the tail and dash lights are connected. So wouldnt that mean that a new fuse should have fixed both problems? Anyway I have a feeling it is my dimmer switch, but how can I check that? Again though wouldn't that also effect the tail lights because they are on the same circuit? Thanks alot guys for any help I am kinda lost here. Last edited by mdmfootball82 : 08-20-2008 at 10:43 PM. |
#5 (permalink) | |
Preserve a 3S
![]() October Quickening Best Performance Modification 2004 & 05 -Stealth- Best Non Performance Modification 2004 & 06 Check out the Links "Stealths in Boston" "The 315-Watt Mitsubishi/InfinityŽ CD Audio System with 7 Speakers" "How to install an Amp on a Stock Infinity System. With pics!" "Dash & Door Speaker alternative, installation, & review" '95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, Radio Control Addition DR-500 turbos, Lucas 550's, RPS Max Street Clutch & Flywheel, Tanabe SM Hyper Exhaust, Greddy Denso, ARC-2, Blitz DSBC, 03 Mitsu Infinity System/in dash 6 Disc Changer Diamond-D971 components, JL e6450 650w 6ch amp Smokin corner box JL W3. 99 lights & fogs w/Hid's . Bridgestone S-03 Pole Position skins. Member #846 6/01 99SL Black (Deb) The first actual 99 Digital Climate Control Conversion Oct. 04, 05, & 06 Quickening "Best Stock" |
#7 (permalink) | ||
3/S enthusiast
Did you tape up the illumination wire so that it wouldn't ground against the chassis?
Mods ------------------------- 1991 Mitsubishi 3000gt VR4---------------My website If you live in the Delaware, Maryland, or Virginia area check out our website and 3si chapter forum |
